Old 07-17-2007, 12:18 PM
Graham S is on a distinguished road
Vertical router project
I've got plenty of other projects on at the moment but the two long stages in this picture appeared on ebay disguised as a pick and place system (along with a load of pneumatics) and I picked them up for just £266 ($544). Seemed rude not to.
The 900W Kress router and the Aerotech stage (5" travel) I already had and were destined for other duties but they seem to match well.
My idea is to configure them roughly as shown but close to vertical with the long rail running from left to right at the top of the cutting area. The shorter stage would be canter-levered off from the large one.
The basic concept is shown in these links:
http://www.denford.ltd.uk/index.php?...d=24&Itemid=29
http://video.google.co.uk/videoplay?...16662326107270
http://fmtmachinery.com/spacemaker.htm
I really just wanted to get peoples opinions. I'm also interested to hear ideas for the bed. Vacuum sounds like a good idea but I don't know what is available, I've also considered t-slots with the slots vertical to keep them clean.
As a further note the motors are Yaskawa 3-phase servos, it turns out the drivers (available via ebay) are capable of running from step/direction, should be pretty cool.
Graham
Old 07-19-2007, 10:36 PM
johnmac's Avatar
johnmac is on a distinguished road
If you clamp the work down, looks like the cut pieces might try to fall out.
Looks like it would save on floor space!
John
Old 07-20-2007, 06:01 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
How to: Counter balance the weight of the router? Will you use some of the pneumatic bits for that? Sliding counter weight? Or just a really stout stepper?
Like the idea of a vertical table - but too many projects right now myself. Will follow with keen interest.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 07-20-2007, 08:02 AM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
John
You use tabs, just like workpieces on a horz. machine to hold into place, I then use a trim router with flush bit to cut the pieces loose, very fast and little final cleanup.
Joe
Old 07-21-2007, 01:29 AM
harryn is on a distinguished road
I really like the idea - of course, I am a bit biased. I started a project log, perhaps a bit early for my actual progress here:
Vertical Table Router / Mill
So far more a parts list and ideas.
Thanks for the link to a commercial system - good example.
For holding work still, I am toying with the idea of putting in a sort of L stop (bottom and edge ) to stop against, and then using a vacuum hold down approach.
I will definitely be following your thread. Good luck.
Harry
Old 07-26-2007, 10:02 AM
Sorry about not replying sooner.
Clamping can be an issue as it can even on flat routers, its always best if parts are not free when cut out so I'll definitely be looking at vacuum beds as well as tabs, sometimes it would also be convenient to drill some holes for holding dowels or bolts.
I don't intend to use a counterbalance as I have a three phase servo lifting the router which is only a small one anyway. I can always modify if needed.
Graham
Vertical Table Router / Mill harryn CNC Wood Router Project Log 80 10-27-2010 12:33 AM
Vertical mounted router table? 307startup DIY-CNC Router Table Machines 15 02-08-2007 09:37 PM
Vertical Gantry Router jdownie DIY-CNC Router Table Machines 4 10-26-2005 06:17 PM
My router project twombo DIY-CNC Router Table Machines 0 11-26-2003 11:30 AM
Router Table vs. Vertical Mill Jcadwell General Metal Working Machines 9 06-23-2003 06:48 PM
