Old 07-16-2007, 12:19 AM
Mr.Nerd's Avatar
Mr.Nerd is on a distinguished road
Question VXB linear bearings
Has anyone ever used or heard anything about the linear rod/rails from VXB bearings? I was looking at the one below to use for a new router.
http://www.vxb.com/page/bearings/PRO...ystems/Kit7429
Thanks in advance!
Old 07-16-2007, 07:13 PM
PLJack's Avatar
PLJack is on a distinguished road
I didn't see any tolerance numbers but I would be concerned about grit getting at those bearings.
Very slick though, I like.
Jack
Old 07-16-2007, 07:18 PM
practicalcnc's Avatar
practicalcnc is on a distinguished road
I would not be that concerned about grit because of the rubber dust boots.
These bearings are made to be used in pairs. So. 300 bucks per axis..
Since light travels faster than sound,people appear bright until you hear them speak.
Old 07-16-2007, 09:42 PM
Mr.Nerd's Avatar
Im actually planning to buy three and cut them to use on all three axis because Im not building a very large maching. Then I would buy some bearings serperately to complete the other axis.
Old 07-16-2007, 10:12 PM
*Registered User*
kavic is on a distinguished road
Thanks for the Link
I'm designing a machine with a 45" x 24" cutting area. The rails and bearing would have cost me >$1000 USD. Buying from VBX, I can get the same thing for ~$650.00 USD.
Old 07-16-2007, 10:49 PM
Mr.Nerd's Avatar
Yep, the price very attractive for me especially because the rails are supported. I know it is possible to get some brand name linear slide rails off of ebay for an even lower price but then you lose the ability to design your machine they way you actually want to.
Old 07-17-2007, 11:26 PM
MRM RCModels's Avatar
MRM RCModels is on a distinguished road
Thumbs up Just Bought a Set Today
Just bought a set today for my machine. I'll report back when they get here. For anyone who is designing their CNC machine using CAD, these have the same dimentions as the Nordex brand rails and pillow block bearings #AGA-A8-4 and #AJA-A1-17. You can download the 3D CAD files direct from http://www.3dcontentcentral.com/3DCo...l/Default.aspx. It requires registration though .
MRM
ID:	40831   Click image for larger version
Name:	20mm vbx rail guides.jpg‎
Old 07-19-2007, 12:06 AM
Mr.Nerd's Avatar
Thanks for the link. Do you know who actually makes the rails? If not do you suspect the orgin of these linear slides to be from Nordex?
Old 07-19-2007, 07:59 AM
Hard to say without physically seeing them in person. I'm almost positve that they are China made or maybe some out of tolerance Nordex batch.
Old 07-19-2007, 09:32 AM
massajamesb's Avatar
massajamesb is on a distinguished road
I bought some of the open bearings (20mm) for my next machine, and was going to use 3/4" CRS as a rail, drilled and tapped every 6 inches. I have 3"x3/8" HR flat that is drilled to bolt to the rods.
I have now found that even though they ride very, very smooth on the CRS, I will have to buy hardened rails to prevent wear issues.
Luckily VXB sells predrilled and tapped rails in 5' sections.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
  #11   Ban this user!
Old 07-19-2007, 01:00 PM
Jusy got off the phone with UPS. I can go pick up the package tonight.
  #12   Ban this user!
Old 07-19-2007, 01:25 PM
Mr.Nerd's Avatar
I emailed VBX bearings and asked who makes the rails and this is the response I got.
" They were made specially for VXB, unfortunately, we don't carry any CAD files"
80/20 linear bearings Ursine 80/20, TSLOTS and other Aluminum Framing Systems 24 12-11-2008 02:58 PM
Linear Bearings teenrocketnerd DIY-CNC Router Table Machines 3 06-25-2007 05:05 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Linear Bearings to many $$$$$ truman Linear and Rotary Motion 19 03-25-2006 01:38 PM
linear bearings broncosis DIY-CNC Router Table Machines 0 06-10-2004 06:03 PM
