Old 07-13-2007, 02:00 PM
rmtucker is on a distinguished road
Another High Speed Spindle Design.
Well it's been a long time since i posted here but i am starting another spindle project and i thought i would share my experiences.
I have been using a 8,000rpm - 28,000rpm Router like most people but had the following problems:-
1.Everytime new bearings were fitted i had to play with shims to prevent endfloat.
2.Bearing life was very short due to vibration and over revving them.
3.Lack of power at any speed below max rpm.
4.Runout on the ER16 adapter i am using was excessive.
After hunting around i eventually found a guy that can supply ER16 extensions that have a step at the bottom to retain the bearings.
This cost me all off £26.00 so it was worth a go.
Let me know what you think initially?
Regards
Mark
ID:	40609   Click image for larger version
Name:	spindle assem1.jpg‎
ID:	40610   Click image for larger version
Name:	spindle assem2.jpg‎
http://www.weardalecnccarving.co.uk
Old 07-14-2007, 08:03 AM
I have decided to try 3 deep groove ball bearings insted of the usual angular contact bearings.
The reasons for this are cost and Max Rpm,The spindle cartridge in total will only cost around £40 excl the machining of course.
Also other than the problems mentioned in the prev post the router bearings were never a spot of bother if changed regular.
I would imagine in this instance that the bearing life will be far greater (Higher quality and faster bearings,also the rigidity of the housing and less runout).
I have attatched the drawing for the spindle body.
Old 07-14-2007, 09:05 AM
This is the drawing for the front cover of the spindle which also holds the front lip seal.
Old 07-14-2007, 09:11 AM
I have also picked up the following items.
2 off - 25mm ID x 35mm OD x 7mm thick double lip seal.
1 off - Aluminium Pulley with guides 20 tooth x 5mm pitch
3 off - 6804zz Deep Groove Ball Bearings
I should start the machining in the next few days,i will post pics as i go along.
Old 07-14-2007, 09:20 AM
ger21's Avatar
What type of motor do you plan on using?
Old 07-14-2007, 09:25 AM
The usual cheap Treadmill 2.5hp motor with 7,500 rpm.
This will be 1:3 on the pulleys so it could achieve 22,500rpm even though i want to max out at 18-20,000rpm.
I even contemplated going 1:6 using an idler and this way i can stop the motor going into orbit.
I have the motor and DC controller working through PWM on mach3 using the little opto circuit that was used on the Cnc zone some time ago by J Fettig i believe.
Old 07-14-2007, 10:18 AM
samakthachai is on a distinguished road
Cool hobby spindle
Normally, I have found most hobby-spindles could drill or engrave on wood,acrylic or non-metal.
It's possible or not if hobby spindle can engrave on metal. example steel,brass,aluminium and so on. How many minimum horse powers does it can? Who know that?
Cheers
Samak
Old 07-19-2007, 09:33 AM
This is the last of the drawings for the Spindle unit.
Regards
Mark
Old 07-20-2007, 04:08 PM
Here is a cross section of the assembled spindle unit.
Old 07-20-2007, 04:24 PM
tsalaf is on a distinguished road
Does the ER extension have a metric diameter?
Can you provide the source for the extention?
Steve
  #11   Ban this user!
Old 07-20-2007, 05:57 PM
Eurisko is on a distinguished road
Mark,
It looks great.
I also plan on making an ER16 spindle, but I think I'll go with the angular contact bearings rather than the deep groove variety.
The AC bearings will handle axial loading better, and 20000 rpms shouldn't be a problem.
Could you please post your source for the ER16 extensions and treadmill motor ?
  #12   Ban this user!
Old 07-20-2007, 06:18 PM
Hmmm Been through this argument before with Angular contact bearings.
I can not find a source for 20mm id bearings that will run up to 20000rpm + for a reasonable amount of money?
I have ran my router for thousands of hours and never had a problem with axial load?
There is only 2 bearings in it but they are run at speeds way beyond there ratings.
I think you are defeating the object of fitting ac bearings on an er16 spindle because the spindle can only hold up to 10mm dia so not a lot of axial load can be applied anyway.
I cut everything from wood to metal and never have any problems other than those mentioned in the first post.
The Dia of the spindle is 20mm and just a nice fit in the bearings.
Regards
Mark
Engraving with High Speed Spindle MichaelHenry Tormach PCNC 7 06-27-2007 07:25 AM
High Speed Spindle Attachment yoopertool Hard and High Speed Machining 6 06-20-2007 06:26 AM
High speed spindle... how high? jonesja2 General Metal Working Machines 0 06-04-2007 07:18 PM
High speed spindle friction fit? Rhodan CNCzone Club House 3 09-05-2006 06:57 AM
High Speed Spindle 10,000 to 40,000 rpm whelen Mechanical Calculations/Engineering Design 5 09-05-2005 08:42 AM
