Old 07-13-2007, 12:50 PM
3Dsigns is on a distinguished road
Rack questions
I just obtained a quote form a company who makes racks.
They quoted a price on 1018 steel racks. Would this type steel be hard/durable enough for the x and y axis of a 4x8 router?
If I mount the rack on the side of my 80/20 aluminum frame, with the teeth facing sideways to eliminate chips collecting in the troughs, and bore the mounting holes through the "tooth side", will these holes cause wear on the spur grears?
Will a rack and pinion system be fairly accurate? Or will it need constant adjusting etc?
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 03:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 12:40 PM
rack and pinion questions klick0 Linear and Rotary Motion 4 05-05-2006 05:54 PM
Rack and Pinion Locster13 Linear and Rotary Motion 2 02-24-2006 09:07 AM
rack and pinion planescott Mechanical Calculations/Engineering Design 4 10-11-2005 03:28 AM
