Old 07-12-2007, 03:52 PM
tahustvedt is on a distinguished road
Another MDF CNC router.
Here's my first scetch for a CNC-router constructed from MDF. I haven't bought any components yet but am watching Ebay for useable parts. I will have to change the drawing to suit whichever components I get.
I planned to use ball screws for the X and Y and a simple threaded rod for the Z axis where precision isn't that important (yet), but then I got to think about belts. I didn't find much info on belts when I searched the forum. Is belt drive a viable solution?
How are ball screws supported when they are direct-driven by stepper motors? I just can't seem to find out by searching. Are they supported on one end by two bearings and the "floating" end connected to the stepper motor, or can the stepper motor support the screw on its own and not cause backlash?
I will use it mostly for 1-2 mm sheet fibre glass and up to 6 mm plywood. Will a Dremel be able to cut that?
Thanks!
ID:	40565   Click image for larger version
Old 07-12-2007, 06:42 PM
rustamd is on a distinguished road
the sketch looks pretty cool. The best way i found on how to find ideas for my build is go browse project log forum. I know it can take few weeks to look through those threads, but then its possible to see what has worked/not for different people. Most of the thread have very many pictures which makes it even easier to get ideas from. Good luck
Old 07-13-2007, 03:48 AM
Guldberg is on a distinguished road
MDF and ballscrews imo doesnt go hand in hand. A chain isnt stronger than its weakest link, so personally i would think you would be better off buying something else for the difference between an acme/trapezoid screw and ballscrews, a good router i.e. The same thing goes for the slider bearings, i would have a look at all the DIY concepts in here, instead of buying expensive stuff. Of cause you can reuse all the items on your next and improved router (which will come:-D ), but for a first learning go cheap (well, it isnt really cheap no matter what you do). I would suggest you started with a well proven design with plans and everything, a solsylva i.e. You learn a LOT building one of these, which you can use designing your next machine.
Just my 2 cents:-)
Old 07-13-2007, 06:09 AM
Ok. I will keep reading the forum. I can't believe I haven't joined here before as I've wanted a CNC router for years.
Is it optimistic to hope for better than 0.1 mm (0.004") accuracy with Acme screws and MDF construction? I will probably feel the need to upgrade the design later like you said.
Making it myself is half the fun to me. I have access to lots of waste sheet aluminium cut-off at work so I can make a MDF/aluminium sandwich construction in some places which should be possible to make very stiff and light if I make lightening holes inthe MCF inside the sandwich. I had some 1.5 mm fibre glass parts cut out by someone with a CNC router in USA and they were nice but had 0.2 mm inaccuracies so I would like to achieve better than that if possible.
Old 07-13-2007, 06:14 PM
Madclicker is on a distinguished road
I think it is optimistic to hope for .004" accuracy with an MDF machine using low end hardware. I just measured a dado i cut that was programmed to be .50". It was .488". .012 is great for what I make. Also gotta split that in half because the dado was cut in 2 passes...left then right, so .006 accuracy on the right and the same on the left.??? Anyway, when I built this i thought I would be happy with .050" accuracy. I was wrong, but have tweaked my machine to perform well for my needs.
Steve
DO SOMETHING, EVEN IF IT'S WRONG!
Old 07-13-2007, 06:27 PM
I added alu/MDF/alu sandwich construction and some drive components. I think I should be able to lighten the MDF between the aluminium skins a lot and still end up with a super-stiff structure.
Since ballscrews are a little overkill I'm going with Acme rods instead. There are dual bearings and nuts for preloading on the end of each acme rod.
Old 07-15-2007, 06:03 PM
I did lots of small changes. I made the sideplates straight because I don't need to center the spindle over the rail trucks with good rails like these I think. I'll turn the acme rods down to 6 mm on one end and use thrust bearings. I think the gantry will be super-rigid.
Old 07-17-2007, 01:27 AM
*Registered User*
Fer1526 is on a distinguished road
I want to build a similar machine like this, but I´m searching for cheaper an eficient parts, wath do you thinck aboth the cable system used in this machine??
http://cnc25.free.fr/planscnc25.htm
(look the palns under "Machine de Guillaume COQUERY (Version à entrainements cables)")
Old 07-17-2007, 07:14 AM
Here's a simple drawing employing the table-integrated machine idea. I think I'll go this route because it's a lot less work to build.
Old 07-17-2007, 10:19 AM
*Registered User*
Yes but look at the plans not for building, the french mahine uses a steel cable intead a timing belt and a small piece of trheaded rod instead a pulley, wraping the cable inside of the tread! similar to this:
http://www.cnczone.com/forums/showthread.php?t=38727
, do you think that this method could work for a cheap router!
P.S.: Excuse my very bad english!!
  #11   Ban this user!
Old 07-17-2007, 02:56 PM
It seems to work well for him. I'm not experienced enough to say how well it would work compared to screws. It's an interesting idea.
  #12   Ban this user!
Old 07-18-2007, 06:01 AM
Buzz9075 is on a distinguished road
IMO #7 the extension of your Z axis is to long and deflection will increase as this length is increased. IMO you should try and keep cutter as close to the parts that hold it to the Z axis, the more you move away the more you magnify any deflections.
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
