Looking for sources for rack and pinion drive components for a 4' x 4' CNC router / plasma cutter I am designing. Also looking for info / suppliers for gear reduction drives to drive the pinion with. Timing belts and pulleys, planetary drives etc. Looking to keep everything cost effective. All advice is greatly appreciated and welcome. Kirk |
| www.stdsteel.com/gear.htm for cheap gear rack www.econobelt.com for timing belt, timing pullies and spur gears. Also check out www.sdp-si.com www.google.com and www.cnczone.com/forums/search.php |
| Yes, I have herd of some people doing that. From what I can tell the 2 best approaches are either rack and pinion or using a belt drive. The belt drive is usually prefered because of maintanence and backlash over the chain drive. Kirk |
| You can avoid some backlash by going with a helical rack and pinion set up. For Heliacal gears and gear racks try www.mooregear.com standard gear racks kept in stock |
| Buy it from the MAKERS? http://www.atlantadrives.com/
__________________ Hey check out my website...www.cravenoriginal.com Thanks Marc |
| Direct drive with stepper on rack and pinion. | jerryrigge | Linear and Rotary Motion | 24 | 10-09-2007 09:21 PM |
| Belt Drive vs Rack & Pinion | babinda01 | Linear and Rotary Motion | 4 | 05-08-2007 06:36 PM |
| Gear Rack and Pinion Gears | Rypper | DIY-CNC Router Table Machines | 7 | 10-08-2006 11:09 AM |
| pushing pinion against gear rack | DanOSB | Mechanical Calculations/Engineering Design | 2 | 02-18-2006 10:02 PM |
| What rack and pinion for direct drive to use. | Apples | Linear and Rotary Motion | 5 | 08-10-2005 05:40 AM |
