Before you answer the question, I will let you know that I did put grease on my timing belts and it quietened them down, and everything seems to be running ok. I am now suspecting that I am going to be told that I shouldnt do so. What are the reasons that I shouldnt, or doesnt it matter? |
| Because they'll get filled with dust, and be very hard to clean. (If your cutting wood or similar materials.)
| Belts are not designed to be lubricated either with oil nor with grease. You are most probably damaging their properties and shortening their lifetime. If they were very noisy, did you check whether they were tensioned correctly? |
| Belts that are old will tend to dry out causing them to be noisy, you may have bought them new but they could have been on the shelf for years. If they are a type of rubber, what I have done with great success over many years is to clean them with brake fluid and wipe dry, this softens the rubber ever so slightly making for quieter running. You do not need or want to soak them just wipe them down and wipe off. A little bit of precaution is in order here, be very careful they are wiped dry before spinning as just a little flick of brake fluid in the eye causes a lot of pain and a little bit on paint will make the paint soft. EDIT: Works on wiper blades as well Ken |
| Thanks guys I will clean them off. When I said noisy, I was probably been fussy, they werent that bad.
| timing belt width? | JFettig | Benchtop Machines | 8 | 01-28-2010 05:34 PM |
| Timing belt length calculator. | dmgdesigns | DIY-CNC Router Table Machines | 2 | 01-05-2009 06:54 PM |
| timing belt reduction | drwc | Benchtop Machines | 6 | 05-23-2005 03:31 PM |
| timing belt question | Aegeon | DIY-CNC Router Table Machines | 6 | 05-18-2005 09:50 AM |
| Any recommended Timing belt and pulley? | starCNC | General Metal Working Machines | 10 | 07-31-2004 11:29 PM |
