Old 07-06-2007, 06:46 PM
luther is on a distinguished road
Question rack and pinion
hello can i use this for the rack and pinion i made the rack myself the sprocket is from a bike thanks
Name:	flash dryer matt teeth 010.jpg‎
ID:	40264   Click image for larger version
Name:	flash dryer matt teeth 013.jpg‎
Old 07-06-2007, 07:16 PM
rustamd is on a distinguished road
I would be worried about backlash on that kind of set up
Old 07-06-2007, 07:33 PM
Question
no backlash felt when i move it by hand.
Old 07-06-2007, 08:04 PM
another problem with using that sprocket is that your resolution would be very "coarse". Example: for one rotation of motor with that sprocket mounted directly to it, you would move 3-4 inches. You would have to make some kind of gear box to get lower ratio to be able to use that setup on router.
Even if using very small sprocket you would face problem of not having enough teeth in contact with "rack". Just my opinion.
Old 07-06-2007, 08:18 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I will say that yes, it will work. The concerns mentioned so far are valid. If you don't need great precision, then this may very well work for you.
It does seem to be a lot of work making that rack, though. I think you will get just as good or better results using the correct chain. You could tack weld or stretch it across this rack you made and it would wear better. The teeth are going to start wearing the rims on the holes pretty quickly with the rack. It would require adjustment often I would think.
Actual chains and sprockets sized like you might need are dirt cheap though.
Surplus Center is where I bought mine.
Lee
Old 07-06-2007, 09:11 PM
know i understand to coarse .i was trying to make something cheap and accurate, any suggestion? thanks
Old 07-06-2007, 09:35 PM
Cruiser is on a distinguished road
I'd bet that the gear will want to lift itself up as it walks your rack, and if it does then it will bind and lurch with every tooth, or if you move axil center then you will have backlash, the only way for it to really be smooth is if the gear tooth form was designed specifically for the aplication, such as a real rack and pinion.
Don
IH v-3 early model owner
Old 07-06-2007, 10:10 PM
massajamesb's Avatar
massajamesb is on a distinguished road
I know you are trying to save a buck and be ingenuitive, but....
A whole R&P setup from Carr Mcmaster will set you back about 175 bucks for 5- 4foot pieces of 20 pitch, 20 degree PA rack, and three spur gears. That may sound like a lot, but how many times do you want to buy something that "might" work, and take forever and a day to build all the mounts and brackets for?
Even using roller chain in a loop on each axis, like the links I sent up earlier in another thread, will set you back about 100 bucks and be much more user friendly than a bicycle sprocket.
Trust me, I speak from experience. I rebuilt my first machine 4 or 5 times before I finally decided to spend the money and buy the right stuff. I hated to spend the money, but I don't want to say how much I wasted on the way to the right parts.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Old 07-06-2007, 10:53 PM
you can also buy cheap gear rack at http://www.stdsteel.com/gear.htm
also try www.econobelt.com for spur gears.
Alternativly you might try using timing belt and timing pulleys, which can be reasonably cheap.
Rack & pinion coolman DIY-CNC Router Table Machines 6 05-07-2006 04:14 PM
Considering rack and pinion phantomcow2 DIY-CNC Router Table Machines 12 03-12-2006 04:05 PM
I need rack and pinion Help t0m CNC Plasma and Waterjet Machines 9 11-16-2005 01:14 PM
Rack and Pinion Hillman Linear and Rotary Motion 1 08-09-2005 04:14 PM
calculatiing pinion size for rack and pinion setup Apples DIY-CNC Router Table Machines 3 05-18-2004 09:36 PM
