| These are plasma cutting machines, but it gives you an idea of how it works. Plasma Table Build Log Including Free Plans Link, & Pictures by Weldtutor and the last page of Smilewizards' thread, 4 x 8 Plasma Table Plans I wouldn't say that chain is not an option, if installed correctly I believe you could get most of the slop out. Perhaps it is not accurate enough for routing, but I know that it does work well on other machines, especially plasma
__________________ (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) "If the women don't find you handsome, they should at least find you handy" -RedGreen show. |
Joe |
| Oh, gotcha. ![]() You are right about that, Joe. I would not try it (chain) as a rack and gear setup. Now, if you were to make the chain taught from one end to the other, and have the driven sprocket on the gantry, with the chain going under an idler, over the drive sprocket, and under another idler, then that might work, but.... In reality, the cost of chain and sprockets is only a little less (perhaps 50 bucks or so) than using gear rack and spur gear. Trust me, I found out the hard way
| Rack & pinion | coolman | DIY-CNC Router Table Machines | 6 | 05-07-2006 05:14 PM |
| rack and pinion | senor J. | Linear and Rotary Motion | 7 | 11-17-2005 05:21 PM |
| rack and pinion | planescott | Mechanical Calculations/Engineering Design | 4 | 10-11-2005 04:28 AM |
| Rack and Pinion | Hillman | Linear and Rotary Motion | 1 | 08-09-2005 05:14 PM |
| calculatiing pinion size for rack and pinion setup | Apples | DIY-CNC Router Table Machines | 3 | 05-18-2004 10:36 PM |
