Old 04-19-2004, 11:01 PM
trent2530 is on a distinguished road
my second router just finished
click on router #2 at http://www.machinecnc.com
Old 04-20-2004, 02:48 AM
arvidb is on a distinguished road
I like the enclosure. That last "humvee" pic is really cool
Arvid
Old 04-20-2004, 07:09 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
trent2530 Trent - Real nice! Like the idea of moving the computer to the machine too - youl'll find a use for the first machine I bet.
Do you have an estimate of the "ballparkl" costs of building the #2? You got the Wisecarver numbers - how about the rest?
Are you getting down to the "smallest" mark on the tape measure -- and the speeds are they up to your expections?
All - in - all, a very good presentation of the thought and effort.
Havent seen that color Humvee yet though - lol
cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 04-20-2004, 08:46 AM
Ballpark costs? Dualvee and track $223, steppers - 3 for $121, Gecko 201's - $114 times 3, power supply - $65, computer - $50, already had the monitor. About $900 altogether. Speed is an honest 60 ipm on 24 vdc and will double if I go to 48 vdc with the same power supply. 230vac in will give 48vdc out. I don't have a number to express the accuracy, but it is tight will no flexing. I did find a use for the first cnc router, the parts were used for the second. The first one was a loose goose.
Old 04-20-2004, 01:08 PM
Zagroseckt is on a distinguished road
you wouldn't by chance have a set of plans for ths guy?
This is the size michene i want. not to big not to small.
Old 04-20-2004, 04:04 PM
boxwood is on a distinguished road
I saw your description of how the weiscarvres are adjusted but wasnt quite clear to me can you give a close up view or drawing of the design thanks
Learn from the mistakes of others you can't afford to make them all yourself!
Old 04-20-2004, 07:48 PM
Hobbiest is on a distinguished road
What is the travel of each axis? Very niceley done. I have enjoyed reading your website for the last 8 months. Thanks for sharing.
Stop talking about it and do it already!!!!!
Old 04-20-2004, 10:55 PM
Plans? I'm thinking about it. I would like to improve this one first.
Bishop Wisecarver has a pdf catalog at their website, just click on the dualvee pictures until you see it. It shows sizes measurements and all the good stuff about the dualvee wheels.
As for the offset hole, picture a hex bolt with a hole drilled the long way through it. And the hole isn't centered, as always. As the bolt is turned the hole and the axis for the wheel will move sideways. In my case, farther or closer to the wheel on the other side of the y axis board or the z axis board. This way the four wheels can put the squeeze on the board.
The size of the slotwall x axis board is 28" by 24". Actual cutting area is about an inch less than that. Z axis travel is 5".
And to be honest, the wood carving duplicator on my site didn't work, it should have been made of metal. The first cnc router did work but too much flex and no speed. The 4th axis might have worked, but the software for 4th axis was beyond my budget for now. And the latest design hasn't cut anything yet. I'm now wading through the software nightmare. So I suggest my website be used as just general info to help one get an idea of how to do cnc. Even info on the mistakes can be useful.
Trent
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 01:17 AM
CNC Router with THK KR46 actuators Finished! pics & video wisp CNC Wood Router Project Log 22 07-08-2005 10:10 PM
Finished CNC router tonight snoman70 DIY-CNC Router Table Machines 1 06-01-2005 05:34 AM
Router is about finished! Now the next step.... using!!! twombo DIY-CNC Router Table Machines 1 02-09-2005 02:59 PM
my new longbed router cncspear DIY-CNC Router Table Machines 16 10-15-2004 08:36 PM
