Old 07-03-2007, 09:10 AM
ChristianW is on a distinguished road
Smile Using steel instead of wood for construction
What would happen if you took, say one of the medium size Solsylva-machines. And constructed the whole thing out of steel instead of wood? Using the same templates and dimensions etc.
If I find a local metalworkshop with a lasercutter, I guess they could fabricate the parts for me without problems.
Would you get a more solid machine, one that you could use for milling harder materials than a wood-built one? Or would you just end up with a heavier version of the same "weak" machine?
Christian W.
Old 07-04-2007, 08:55 AM
Guldberg is on a distinguished road
Heavier version of a weak machine:-) Imagine the weight of this thing if you used the excact dimensions!! The gantry alone would proberly weigh atleast 100kilos:-) Steel is by no way a bad thing, im doing one made of lasercut parts myself at the moment, but the solsylva plans are for a machine easy to make using wood and common tools. If you want to make one of steel, make your own plans or look at the free mechmate, thats a sweet (and big) machine made up (mostly) of lasercut and bended plates.
If you by harder materķal mean aluminium, proberly a steel one would be better, but dont count on milling things like steel or similar, there is a reason a real mill weighs as much as it does:-D If this is what you want, instead look at converting a small mill like the x3
help in construction! drumbuilder Wood Lathes / Mills 13 01-28-2008 08:43 AM
Plans for steel construction? AndyL DIY-CNC Router Table Machines 1 03-19-2007 06:57 PM
Milling Steel with a Retroed Wood Router whiteriver Commercial CNC Wood Routers 2 07-08-2005 07:27 AM
construction plans owhite DIY-CNC Router Table Machines 0 01-19-2004 11:07 AM
I-Beam construction chuckknigh DIY-CNC Router Table Machines 5 08-14-2003 01:18 AM
