Old 06-30-2007, 09:31 AM
studysession is on a distinguished road
My first build log of my belt drive DIY CNC Machine - PICs
I know it looks like poop. It does work and it is pretty accurate. I also still have a lot to finish on this thing. It has a cutting area of 6 ft by 4 ft. The structure is 10 series 8020 aluminum.
Will have a rotary as a forth axis. Using Mach3 as control software. I still have a long way to go. I have a lot to still learn.
In the beginning I wil start with wood so ordered this chuck here for my rotary:
http://www.pennstateind.com/store/csc2000c.html
Faceplate that chuck will screw to and then attach to rotary:
http://www.pennstateind.com/store/cf6.html
Will make an adaptor for my rotary to the faceplate and use it.
http://www.cnczone.com/forums/attach...8&d=1183209742
Please check out my CNC blog
http://cncinside.com
Old 06-30-2007, 09:35 AM
More pics - remember I am not finished. This is a work in progress.
I want to fully enclose everything behind plexiglass when it is finished.
ID:	39899   Click image for larger version
ID:	39900   Click image for larger version
Old 06-30-2007, 02:24 PM
harryn is on a distinguished road
Hi - looks pretty good. Are those drawer or skate bearings ?
Old 07-01-2007, 11:24 AM
They working pretty well. Right now my main consern is the gantry. Trying to see what will give me the most support. Today will do some engraving on 1/4" thick MDF for practice.
Old 12-26-2007, 01:30 PM
rlrhett is on a distinguished road
Studysession,
I see that you have fixed motors, so I assume that the gantry is attached to the timing belt itself at a fixed point. Can you show how you made that attachment?
Thanks,
Old 12-26-2007, 04:42 PM
Originally Posted by rlrhett View Post
Studysession,
Thanks,
Sure - over the last three days I re-did most everything. When I find the cable for my camera, I will upload pictures. It is much more sturdy and not just down on the floor anymore. Also a bit smaller. Has a cutting area a bit more than 4 ft by 3 ft now.
Old 12-26-2007, 09:58 PM
Here are the pics. I built a wooden base for it all to sit on. As you can see there really isn't much to it.
The picture showing the mounted z-axis from behind looks a bit tilted, it was the camera not the z-axis. I did not hold the camera straight.
ID:	49341   Click image for larger version
ID:	49342   Click image for larger version
ID:	49343   Click image for larger version
Old 12-26-2007, 10:17 PM
One more thing -
I did not make the bearings myself even though I could have. Not a big deal but purchased them from here:
http://stores.ebay.com/HUBBARD-CNC-INC
I also purchased my stepper motors from him as well.
Motor Specifications:
NEMA 23 282 oz-in stepper motor
200 steps per revolution
1.8 degrees per step
Bipolar series Volts=3.864, Amps=2.1, Ohms=1.84, Holding torque=2.0 Nm.
Bipolar parallel Volts=1.93, Amps=4.2, Ohms=.42, Holding torque= 2.0 Nm.
Unipolar Volts=2.76, Amps=3.0, Ohms=0.92, Holding torque= 1.4 Nm
Dual shafts, Main = 1/4" x 20 mm, Back shaft= 1/4" x 15 mm
http://cgi.ebay.com/Stepper-motor-28...QQcmdZViewItem
Old 12-27-2007, 09:35 AM
Finally have amy issues worked out. The cutting is so much smoother now. Attached is a pic of the sign I am cutting out onto balsa wood. It will be small 6 in by 12 in. Good to put on my friends desk at his place of business.
The software used for rendering is VCarve Pro 4.6
Old 12-30-2007, 05:22 PM
gascarracer is on a distinguished road
How are the belt Drives working?
Ernie
  #11   Ban this user!
Old 12-30-2007, 05:35 PM
Originally Posted by gascarracer View Post
Ernie
I am happy with them.
  #12   Ban this user!
Old 01-16-2008, 08:45 PM
daburdge is on a distinguished road
Realy nice machine! Im just starting mine and want to use belts and pulleys too. Any ideas on where to get the belts and pulleys? And what kind?
Can I Build A Cnc Table Out Of These Parts?? Pics douglasco Open Source CNC Machine Designs 12 11-03-2008 06:34 PM
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 10 03-01-2008 05:02 AM
CNC Gantry Painter Build Pics - Night 2 vacpress Printing, Scanners, Vinyl cutting and Plotters 7 11-02-2006 07:52 AM
New CNC machine build (big pics) ckm Vertical Mill, Lathe Project Log 11 09-03-2006 03:03 AM
CNC Gantry Painter Build Pics - Night 1 vacpress Printing, Scanners, Vinyl cutting and Plotters 29 04-09-2004 05:43 PM
