Old 06-28-2007, 10:44 AM
droddis is on a distinguished road
Stepper Motors ???
Does the stepper motor turn the middle metal bar and the nut the moves along and the guides keep it level? or am i way off?
David
Old 06-28-2007, 11:13 AM
pminmo's Avatar
pminmo is on a distinguished road
I'm not completely sure of your question but I'll post this. Level and alignments are handled by guides. All kinds of methods are utilized, pipe and skate bearings, metal angle and skate beatings, drill rod, metal tube, and true linear shafts and bearings. Probably the vast majority of drive from motors, stepper or servo are motor shafts coupled to threaded rod for rotational movement with a fixed nut on the axis mechanical to convert to linear motion.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 06-28-2007, 12:04 PM
I think i understand.
On each axis there are two guides either side with ball barings on a L-plate. The centre threaded rod is attached to the stepper motor, on the rod there is a nut fixed to the platorm/table. as the motor makes the step the rod turns, and the table moves in the appropriate direction. ???
is this right
Old 06-28-2007, 01:06 PM
pminmo's Avatar
Yes
Old 06-28-2007, 05:54 PM
Thanks Very much i understand how the machine works now. Thanks
Has anyone used MCG Stepper motors CATCH22 Stepper Motors and Drives 1 05-20-2007 01:06 PM
Stepper Motors OG Style Stepper Motors and Drives 0 08-25-2006 04:38 PM
Stepper Motors Bob Cole DIY-CNC Router Table Machines 2 12-31-2005 04:16 PM
Stepper motors in the UK. Kammo1 Stepper Motors and Drives 0 07-05-2005 05:29 PM
Stepper Motors kellogs72 Stepper Motors and Drives 1 11-29-2004 08:27 PM
