Old 06-26-2007, 11:44 PM
jimluu is on a distinguished road
Router spindle for cutting aluminum
hi. I'm almost done gathering parts for my first machine. I do mostly wood, with some foam cutting. It just occurred to me that it would be nice to be able to cut aluminum as well. I'm set up right now to use a bosch 2.25hp router....is this adequate to cut aluminum or should I look for another option? thanks. jim.
Old 06-27-2007, 12:36 AM
ZipSnipe is on a distinguished road
Routers cutting alum are just too damn fast!! And you need to flood cool the bit otherwise it just gums up until it breaks. But I,ve seen guys on here get some decent cutting in alum with a router. Hopefully one of 'em will chime up.
Old 06-27-2007, 02:43 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
spray bottle with soapy water works if you don t want to oil up your system,
if your not overly concerned about it then wd40 works well
if you want to be experimental , you may be surprised to see how well a cheap carbide tipped router bit works ,they have lots of clearance and wont clog up too quickly ,good chip evacuation , a bit lighter of a cut is necessary than you would with an endmill
Old 06-27-2007, 04:35 AM
Guldberg is on a distinguished road
Go at lowest speed, usually 10k rpm and very light cuts <0.25mm but at fast feedrate ~800mm/min. That works for me and avoid gumming up the chips. Use spirits for lubricant when milling alu, only disadvantage is that you tend to get a headache. Soapy water or cooking oil will also do the job (oil creates a lot of mess though)
Old 06-27-2007, 10:03 AM
fr0st is on a distinguished road
How are people getting around the fact that MDF soaks up liquids? or are MDF based machines too flimsy to mill aluminum to start with?
Old 06-27-2007, 02:41 PM
dertsap's Avatar
Gold Member
paint the mdf
Old 06-27-2007, 07:55 PM
martinw is on a distinguished road
Dear Jimluu,
You can get specialist router cutters for aluminium that are designed for use in 1/4" and 1/2" collet "woodworking" routers. Loads of aluminium frame window fabricators use them.
The cutters are HSS, solid carbide, or carbide inserts.
They work really well if you take really light passes.
For a cutting compound, I've had good luck with paste wax. Specialist ones are available. It traps the swarf, and doesnt spray all over the place.
I've surface milled blocks of aluminium with a 5/8" diameter carbide insert bottom cutter, and the results were surprisingly good.
Do yourself a favour, wear eye protection. With the wax, you may not need it, but why risk it.
Best wishes
Martin
Old 06-28-2007, 11:59 PM
yoopertool is on a distinguished road
This may sound a little odd, but when I am milling aluminum and dont want a big mess of coolant or oil, I use crisco. Just go buy yourself a tub of crisco shortening and a paintbrush. Simply wipe a layer of the shortening on the surface and you are good to go! You can even get flavored shortening to make your shop smell nice
Old 06-29-2007, 02:28 AM
dpot's Avatar
dpot is on a distinguished road
sounds great what is crisco at the moment i use slow speeds and rube wax's on the, when the it cuts the wax melts it OK but not grate
Old 06-29-2007, 03:47 PM
Thanks for all the great advice. Looks like the router should work. I'm a bit worried about using any types of lubricant since the router is not sealed for liquid. Is there a better spindle that is not super expensive?
  #11   Ban this user!
Old 06-30-2007, 04:44 AM
dpot's Avatar
this may seam odd but can you see this comment in the thread quote
(Do not speak unless you can improve the silence)
if so I am interested in what crisco is so i can improve the cutting of aluminium on my cnc, so a reply would be good
I posted my tip using wax and stated it is good but not great
I am fast wondering whether it is worth bothering to post
it getting to be making money or grabbing as Much as you can
Old 06-30-2007, 05:01 AM
dertsap's Avatar
Gold Member
crisco is shortening (fat), used for making light flakey melt in your mouth pie crusts
Cutting .020 Sheet Aluminum on a CNC Router Mini-MillX2 General Metalwork Discussion 12 05-01-2007 07:21 PM
Cutting Aluminum darylprice DIY-CNC Router Table Machines 7 07-03-2006 11:51 AM
Aluminum cutting router sdantonio General Metal Working Machines 7 03-28-2006 05:33 PM
K2 cnc Aluminum Cutting Ed Williams General Metalwork Discussion 0 03-16-2006 01:38 AM
CNC Router cutting Aluminum 2Gs DIY-CNC Router Table Machines 7 08-09-2004 09:21 AM
