#25
Here are the three pieces of the puzzle. I got the encoder (oops I mean the gearbox ) apart and these are the relevant bits. Note the dissimilar metal in the encoder (gearbox) shafting mount. I think I may wind up "loosing" the large diameter disk (with the 3 short shafts - they hold other gears in place in the gearbox) when I try and bore/drill the main shaft. In any case, the 3 short shafts are in the way. I suppose I could build a coupling that mounted the -------- shaft to the PACSCI motor - but the height really starts to stack up then -- nearly the length of the original Globe Motor! Anyhow, I'd like to keep the _________ shaft as long as possible. The largest diameter of the ________ shaft looks like a good spot to place a set pin or screw. Follow ups as i get it sorted. Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. Last edited by High Seas; 07-18-2007 at 08:16 PM. Reason: Tech terms GEARBOX not ENCODER!! |
#28
| I use a sherline rotary with a 4 jaw chuck. The chuck attaches to the rotary with a threaded adaptor spececifically made for the task. The rotary attaches to the mill table with 90 degree adaptor. The 4 jaw works well because it will grip flatstock and hold it between a tailstock or it will grip square or round stock. Round stock being my preferred method. I usually mount my wax or pewter rough stock to a round mandrel which is mounted in the chuck. The method I mentioned works well for those two materials(wax pewter) and improvision will obviosly be needed for other materials. |
#29
| Graham - missed your post and headed to the workbench. After much careful consideration and a bit of luck, I got the pilot hole and the follow up --"Spot On." Then used a sizable drift punch and popped the shaft out of the planetary hub. Was press fit into the center - note the splines on the shaft and in the hub. The hole is deep enough to permit me chopping the splined portion off the shaft. I could find no useful bits on the encoder end - so dug into the gearbox. Figured I'd find some joy there - as that the business end that drives the rotary! Now to find a set screw (tap, etc) and I'm away! Well, soon time to tackle another project. Jim
__________________ Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it. |
#31
| Same error when I did the photos -- beer? Wot not RUM! (maybe G&T) AND I did learn too - the Planetary (gear) Shaft! [But wasn't until your post minus 1 I got it sorted] SEE - EXPERIENCE! Just hope there is no bill to pay - else I have another one waiting in the wings as a spare if I need a redo. JimI'll work the stack up tomorrow and see how it all fits together. Then we'll know if we're close enuf. It'll be a few days 'til trial/ops check - other projects gotta fall into place first.
#32
| Like the mount. I want to use your design, I like that. Also looks more sturday than what I am doing. Been dealing with family problems so not been working on it few couple weeks. I want to get it done and really like the mount you made. Thanks for posting.
__________________ Please check out my CNC blog http://cncinside.com Last edited by studysession; 07-20-2007 at 04:30 PM. |
#34
| studysession - Yep - but I cheated a little bit. I had drilled the shaft (That"s the Planetary gear Shaft!), then put the punch down the hole and a few gentle taps - bing! Sweat as you please. I gotta admit I feel very lucky getting as close as I did on the drilling. Take care in that bit! Might use the lathe as Graham suggests. And caution -- my PACSCIs are 1/4 inch shaft - so that doesn't leave a lot of meat when you get to the sides of the planetary shaft where its flattened for the gear. As a compensation I didn't drill as deeply as I'd have liked. SO I get to make a new backing for the mount (tomorrow maybe) to take up the void. I suspect you could just whack away with a drift punch before drilling. I built a small wood jig to use on the drill press and the whacking place. Didn't shoot any pics of that incriminating activity ![]() Hope that helps Jim
| 60$ rotary table? | vacpress | General Metal Working Machines | 22 | 10-30-2007 07:12 AM |
| Cnc Rotary Table | BAYWATCH-TIM | General Metal Working Machines | 2 | 10-31-2006 03:11 PM |
| Looking for a rotary table | gto7419 | General Metal Working Machines | 4 | 06-11-2006 07:37 PM |
| Useful for Rotary Table? | Ken Stuempge | Mechanical Calculations/Engineering Design | 2 | 02-12-2006 09:16 AM |
| Cross slide work pc on rotary table | replicapro | General Metalwork Discussion | 4 | 07-08-2004 05:30 AM |
