Old 06-19-2007, 04:24 PM
Trainhound is on a distinguished road
1/16th inch mills how to hold?
I have a Rigid brand trim router on my machine and I need to use 1/16 inch bits for some engraving detail work. Is there any tool holder I can buy to chuck in my 1/4" router collet? I'd like to use some very small dremel type bits.
Old 06-19-2007, 09:18 PM
rustamd is on a distinguished road
You may try to use something like this:
http://www.mlcswoodworking.com/shops.../adapbush.html
steps per inch Chris Tucker Linear and Rotary Motion 12 08-14-2008 08:50 AM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 01:35 AM
rectangular tube 1/16th wall...tap or thru slp_prlzys Mechanical Calculations/Engineering Design 16 06-22-2006 07:55 AM
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 03:06 PM
turns per inch vs threads per inch pminmo DIY-CNC Router Table Machines 12 08-18-2004 10:27 AM
