Old 04-13-2004, 12:10 PM
teilhardo is on a distinguished road
Nominations for leader of the CAD plans
See thread:
http://www.cnczone.com/forums/showth...0515#post30515
For details
Please nominate some people that we can use to organize the Cad plans. If we get a lot of results, we'll ask the leading contenders and see if the accept or reject the nomination(s)
>>>Please post on this thread<<<
Thanks all,
Tei
-Please check out my webiste-
http://www.teilhardo.com
Old 09-11-2005, 12:47 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
volenteer 1
Hello,
I have built several machines, I will offer CAD (Rhino), services, Advice on mechnaical hook ups, Mach 3 controllers both Lathe and mill.
I will also provide CAD/CAM/Machining at a extreamly reasonable cost for those new folks needing some parts made on a Mill or lathe.
My Current machine is a shoptask 3 in 1, Eldorado, 2 axis lathe , and 4th axis mill, (about to be 5th in about a 1-2 months). I will be back in the states in about 2 months from my Army trip to Iraq........hehehe, then I would be glad to help, (part time help, though, I could only work on this stuff after my day job is done).
I can convert "Hand drawn", Engineering plans to CAD and then a part. BUT, the part will be only made via the information you give me, if you forget to tell me about a screw hole or something, then it will not be there.
I have Autodest Inventor, and Mechanical, but I just go them, and I am still learning them, for now everything I do is mostly in Rhino or OneCNC.
Poppa
=>Access Free CAD Projects CAD Ground Product Announcements & Manufacturer News 7 05-23-2005 01:03 AM
=> New CAD Projects Available CAD Ground Employment Opportunity 3 05-16-2005 02:45 PM
CAD Drafters Needed CAD Ground Employment Opportunity 0 03-11-2005 11:05 AM
How many building the cad cut cnc router? jsatter DIY-CNC Router Table Machines 7 07-26-2004 03:10 PM
Cad Cut Cnc Router Plans On A Budget ???? jsatter DIY-CNC Router Table Machines 1 11-27-2003 06:17 AM
