Old 06-15-2007, 05:25 PM
SPEEDRE is on a distinguished road
Spindle Tool?
Hi guys, here's an idea I had. What would be the problem with using a pneumatic straight die grinder as a spindle. I have used them at the shop, and they seem to take a beating at high speeds and, under varying loads. I thought what if I could attach a pulley to this?
Old 06-16-2007, 04:14 AM
andy_ck87028 is on a distinguished road
how does the pulley fit in to what you have in mind?
Andy
Drat, imperfection has finally stopped working!!
Old 06-16-2007, 07:40 AM
ger21's Avatar
You'll need a big compressor, that will probably run all the time.
Old 06-17-2007, 06:25 AM
Try....
http://www.abc.net.au/tv/newinventors/txt/s1794042.htm
Australian invention .... worth plugging given above ...
Andy
Old 06-24-2007, 08:58 PM
Sorry for the delay in responding, short term memory shot I guess, lol. What I had in mind was using the straight line version as an electric motorized spindle. I was thinking since the tool can take a heavy side to side load it could make a perfect spinde when mated to a high speed motor. Not air but electricity as power. Have any comments on this type of application?
Spindle will not orient at tool change chipsahoy Fadal 4 07-16-2006 09:39 PM
VF4 Spindle Adustment tool emergent Haas Mills 2 03-23-2006 10:29 PM
Question about missing tool in spindle AMCjeepCJ Milltronics 0 01-31-2006 12:55 AM
Spindle Bearing/Tool Carousel Motor??? AdvancedMfg Industrial Hobbies (Support forum) 0 12-04-2005 10:25 PM
Tool holder for spindle. bunalmis DIY-CNC Router Table Machines 1 07-19-2005 05:56 PM
