Old 04-13-2004, 11:21 AM
I'm getten there!
dmgdesigns is on a distinguished road
Question Is it legal to mix inch and metric ball screws?
Mark
DMG Designs
League City, Texas
Old 04-13-2004, 11:27 AM
buscht's Avatar
buscht is on a distinguished road
Yes, it doesn't matter as long as the ball screw and ball nut match. Each axis can be different. I use TurboCNC and it allows you to set up each axis independantly.
You may get a different top speed out of each ball screw however and your accel and decel may be different.
Old 04-13-2004, 11:33 AM
HuFlungDung's Avatar
Moderator
One precaution is to check that the controller software can still do circular interpolation with different pitch ballscrews.
Old 04-13-2004, 12:00 PM
I'm getten there!
Thanks for the info.
Hu
This may be impossible to answer but of the most popular controller software I see on this site which will not work with mixed ball screws?
Mark
DMG Designs
League City, Texas
Old 04-13-2004, 12:52 PM
Al_The_Man's Avatar
Just about all of the systems I have used that use encoder feedback simply accept the number of counts equal to the unit of the system you are using, i.e. counts/inch. So it is usually immaterial what the ballscrew lead is.
Al
DRO - Metric or Inch DJ Morrow General Electronics Discussion 2 11-15-2004 03:06 PM
Turns per inch to metric conversion sixpence DIY-CNC Router Table Machines 1 08-28-2004 03:19 AM
Metric vs Inch - arguements pro & con DJ Morrow Mini Lathe 10 08-12-2004 09:46 AM
