Old 06-13-2007, 01:04 PM
Gold Member
freak_brain is on a distinguished road
Size problem with stepper machine
Hello All
I have just finished my second machine and have ran into an unexpected problem. My machine will not hold size properly. What I mean is this...
When I set the "steps per", in mach3, to cut a 1" slot to the correct length and then cut a 6" long slot it is off by .03" or so. If I then set it to cut the 6" slot correctly it then cuts the 1" slot wrong. The backlash is good and I programmed the "slop" out by feeding to position before cutting into the part. I get the same result in both X and Y axis. It also happens when cutting circles, squares or any other figure. It's almost like it is scaling or something but the scale is set at 1.0 in mach3. This is a stepper machine with rack and spur gear, Mach3, gecko drives. Any suggestions on what my problem could be?
Allen
stepper size required bru Stepper Motors and Drives 1 12-24-2006 03:38 PM
Stepper motor size corydoras Open Source CNC Machine Designs 2 10-22-2006 12:13 AM
stepper motor size nymachinist Mini Lathe 1 02-21-2006 05:34 PM
Problem machining accurate size part on my Bridgeport CNC conversion fastturbovet General Metal Working Machines 5 05-24-2005 01:01 AM
Z-axis...what size stepper ? dmoore3008 DIY-CNC Router Table Machines 1 05-08-2003 08:13 PM
