Old 06-10-2007, 11:20 AM
anil is on a distinguished road
router for cnc welding
hi all of you newbiie here,would it be possible to use these routers for mig welding, not in a position to invest on a welding robot. any information or links would be helpfull.
Old 06-14-2007, 10:39 AM
SmokinErb is on a distinguished road
I was wondering the same thing. Any info would be helpful
This site changed my life ----> www.alittlebiteasier.net
Old 06-14-2007, 12:47 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
You might be able to use a router for mig welding, If the mig gun was mounted vertical (nozzle down).
The problem would be that welding robots (the robots I've ran) are 5/6-axis bots. A router is prob. only 3-axis.
The reason the mig bots have so many axis is to control things like undercut etc...
I'm not saying that it can't be done, with a router, it might work for lots of simple repetive welds?
Old 06-18-2007, 03:12 PM
dan_the_welder is on a distinguished road
Welding Robot
The main issue as I see it is that for anything other than a linear weld I.E. in a totally straight line it's not going to work.
I do lots of manual welding and you have to constantly change the torch angle, especially on curves.
If you want to build a 5 axis head to hold your torch then you got it made.
Otherwise you could manually set your torch angle and weld straight lines.
Dan
welding equipment fourperf Fadal 8 03-13-2007 10:08 AM
New to TIG welding johnsguns1 Welding, Brazing, Soldering, Sealing 10 03-01-2007 07:56 PM
Welding Larger CNC Router tables Sub thread jsage Open Source CNC Machine Designs 1 02-03-2007 04:19 PM
Welding a Gap Hellbringer General Metal Working Machines 12 06-06-2006 12:50 PM
welding jig georgebarr Welding, Brazing, Soldering, Sealing 2 05-23-2004 07:47 PM
