Old 04-10-2004, 07:07 PM
natchez is on a distinguished road
3x6
does any know how long a rail you can use on a cnc without supporting it please let me know
Old 04-10-2004, 10:03 PM
ToyMaker's Avatar
ToyMaker is on a distinguished road
How big and what kind of rail? 1 inch drill rod is going to need less support than 1 inch gas pipe.
What kind of load? a foam cutter will need less support than a mill for steel.
A little more information in the question might yield some answers.
robotic regards,
Tom
Middle age is when work is a lot less fun - and fun a lot more work.
- - Bob Hope
Old 04-10-2004, 10:10 PM
1 inch solid steel rod i am going to use a router or maybe something smaller
Old 04-11-2004, 09:48 AM
ToyMaker's Avatar
OK. Let me see if I can stick my neck out here and not step too heavily on it
Given:
1. This is the woodworking forum so you're building a wood router.
2. The thread subject is 3x6 so you are going for a 3 feet by 6 feet footprint (cutting area somewhat less).
3. Your router is about 1 horsepower, 110Vac.
4. You can live with 0.030 (~1/32 inch) accuracy.
5. You plan on solid end supports for your rails.
6. You have a very rigid base to build on.
Answers:
A. Your 3 foot span (Y axis) will probably be ok with just end supports.
B. Your 6 foot span (X axis) will need at least one center support.
robotic regards,
Tom
Some people complain because God puts thorns on roses, while others praise God for putting roses among the thorns.
- - anonymous
Old 04-11-2004, 10:24 AM
i am using thompson pillow blocks the closed type so should i just built 3x3 instead of 3x6
Old 04-11-2004, 08:49 PM
bean7795 is on a distinguished road
slides
You could go with the open pillow blocks and buy one of there shaft supports and keep the 3x6 idea
Old 04-11-2004, 08:55 PM
i cant seem to find to open pillow blocks at a decent price as soon as they hit ebay there gone
3x6 natchez DIY-CNC Router Table Machines 0 09-12-2004 03:36 PM
3x6 natchez DIY-CNC Router Table Machines 2 05-05-2004 02:39 AM
3x6 natchez DIY-CNC Router Table Machines 4 04-26-2004 10:34 PM
3x6 natchez DIY-CNC Router Table Machines 5 04-09-2004 11:29 PM
3x6 natchez DIY-CNC Router Table Machines 13 04-02-2004 09:30 PM
