  #25   Ban this user!
Old 04-15-2004, 07:49 PM
aghobby's Avatar
aghobby is on a distinguished road
The easiest way to build this is to copy the concept found on the heavy duty woodworking equipement.
The kind of machine that i repair have 8 motor mounted on a rotating plate. The tool hare permanently mounted with a collet on each motor, each time you call a tool change, the plate rotate to point to good motor. It's like a revolver. I think of using this principe on my second machine, using 2 or maybe 4 porter cable router mounted on an aluminium plate rotating with a gearbox with an encoder mounted on it. You only have to program some macros with mach2 an wire home switch on the plate and youre done!! Not easy as talking of it but i think it's the most easy to build. I prefer to work on electronics than complex mechanics.
I have attached a picture of the machine i'm talking about.
Alex
www.ebfcnc.com
  #26   Ban this user!
Old 04-16-2004, 10:59 AM
HomeCNC's Avatar
HomeCNC is on a distinguished road
An M06 is the tool change code. I change it manually. It is difficult to make an auto tool changer when your using a standard router like a Porter Cable. There is not through the spindle hole to use a draw bar on.
Jeff Davis (HomeCNC)
http://www.homecnc.info
  #27   Ban this user!
Old 04-16-2004, 03:40 PM
aghobby's Avatar
With the revolver, you not change the tool, but the complete motor, no drawbar needed!!
Alex
www.ebfcnc.com
  #28   Ban this user!
Old 04-17-2004, 12:20 AM
tpworks's Avatar
tpworks is on a distinguished road
Is this something of interest?
http://groups.yahoo.com/group/minitoolchanger
http://www.homeshopaccessories.com/
...He who makes no mistakes makes nothing! ...
Tom
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 10:12 PM
2nd Generation CNC Router Design 32.5” X 14” X 6” gregmary DIY-CNC Router Table Machines 9 03-24-2005 04:46 PM
Router bit feed rates. ynneb DIY-CNC Router Table Machines 3 05-28-2004 11:54 AM
buscht's cnc router buscht DIY-CNC Router Table Machines 25 04-13-2004 11:43 AM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 10:18 AM
