  #37   Ban this user!
Old 04-14-2004, 11:51 AM
DW61 is on a distinguished road
I have bearing block at both ends, made out of MDF on my machine (it takes a milling machine to make a milling machine). I have roller skate bearing in the blocks with nuts holding them in place. The all-thread is ~36" between the bearings. I think this is why I am getting so much whip when the all-thread spins at 600 rpm.
DW61
"When in Touble, You Call DW"
(Theme from Dark-Wing Duck)
Old 04-14-2004, 12:21 PM
ger21's Avatar
Try pulling them tight between the bearings, and lock them in place to hold the tension. It might help a little, but you're probably just asking to much from the 1/4-20.
  #39   Ban this user!
Old 04-14-2004, 03:47 PM
radio-op is on a distinguished road
I'm glad to hear of the positive improvement on your table DW61, as well as the discussion you sparked. I for one have 'designed' by the rule of "if it worked for him, should work for me." My first 'instinct' would have been to save for bigger motors, which in your case is the most costly route. The design trade-offs concerning steppers continues to surprise me.
Bill
Stepper Motor High Torque Low Amp Sanghera Stepper Motors and Drives 13 03-21-2005 06:16 PM
Low torque swarfmacdaddy Stepper Motors and Drives 9 12-29-2004 01:47 PM
singing motors, no torque swarfmacdaddy Stepper Motors and Drives 2 12-13-2004 06:06 AM
Stepper question: torque re: current cnczane Stepper Motors and Drives 14 10-21-2004 08:30 PM
dc servo motor torque SJ781 Servo Motors and Drives 19 06-08-2004 03:38 AM
