Old 05-29-2007, 08:07 AM
barnon is on a distinguished road
What's my Problem?
I keep loosing the islands on the D's and A's when cutting letters out of MDF. This is 1/2 inch MDF using an 1/8 inch spiral high speed steel cutter at 60 ipm. Letters are 1/8 inch deep.
Thanks for any help.
Old 05-29-2007, 08:13 AM
LeeWay's Avatar
LeeWay is on a distinguished road
You may try reversing the cut direction. Two passes rather than one might help with it as well.
Lee
Old 05-29-2007, 02:02 PM
srmaietta is on a distinguished road
MDF can be flakey and weak.. are you using an up cut bit? maybe that is ripping the little islands out. perhaps try a downcut.
~Steve
Old 05-30-2007, 12:01 PM
I'm using a upcut. Thanks guy's I will try you suggestions.
Old 06-03-2007, 03:09 PM
SmokinErb is on a distinguished road
are the "Islands" in the D and A being ripped out or is the cutter cutting where it shouldn't be?
This site changed my life ----> www.alittlebiteasier.net
Old 06-03-2007, 03:20 PM
spunky1974's Avatar
spunky1974 is on a distinguished road
Yup.....looks like a upcut versus downcut issue to me.....
When architects and engineers fail ......my phone rings....go figure! LOL What next?
Old 06-05-2007, 11:21 AM
They are being ripped out SmokinErb.
Old 06-05-2007, 11:28 AM
LeeWay's Avatar
~Steve
I really despise MDF. I have cut truck loads of it and I avoid using it at all costs. It has its good points, but they don't outweigh the bad.
Lee
G52 Problem j-radkemachine Haas Mills 1 04-19-2007 06:09 PM
The G01 & G71 problem!!! Darkos General Metal Working Machines 3 08-24-2006 04:12 PM
Problem impact Xylotex 1 03-12-2006 01:53 PM
Problem - Need Help gary-cook Mach Software (ArtSoft software) 1 06-09-2005 03:55 AM
Help.....G90 and G91 problem turmite G-Code Programing 5 02-14-2004 11:36 PM
