#16
| Bill, Thanks for the pics, now I understand. I do have a question, however. You said you'd chuck the rod and use a file to turn down the ends. One end is several feet away and none too stable, I'd assume, and the other end is in the drill. Am I misinterpreting (that's just so rare for me )? |
#20
| kcoaks , yes you right but I use a rod about 1 1/2 longer then needed, then apply the file up near the chuck. After I bring it down to size, cut off the part that was in the chuck. It wastes a little but works for me. If you need to mill both ends, just allow enough to chuck the rod on both ends. The biggest problem I have with the drill motor is the runout and wobble at the chuck, I have found that my drill press works out better. Bill |
#22
| You probably arleady know this, but it would also be a good idea to make a simple bearing block for the rod your turning. Make it out of a a chunk of wood or delrin. Clamp it to the drill press table and position it so it contains the free end of the rod. You don't want to damage the rod, or worse yourself, by having it whipping around. |
| Tool length sensing! | Swede | FlashCut CNC | 15 | 10-12-2005 07:51 PM |
| (possibly stupid) stepper question | anthony | Stepper Motors and Drives | 1 | 05-03-2005 10:07 PM |
| OneCNC stupid question of the day. | bgriggs | OneCNC | 1 | 04-20-2005 09:53 AM |
| New here, 1st stupid question! | FXRocket | General Metal Working Machines | 4 | 11-03-2004 09:04 PM |
| Tool Changer Problems | Snel | Haas Mills | 5 | 08-11-2004 08:56 AM |
