Old 04-07-2004, 02:20 PM
PaulSwany is on a distinguished road
Getting Started
I just found this forum... Extreamly informative.. but there is sooo much information to wade thru... I want to get a good understanding of what I need first before I dive into the details.
I'm wanting to cut balsa wood parts for a RC Airplane kit I produce. The machine should have the capability to cut a 4" x 36" x 1/2" piece of balsa. I'd like to keep the costs down under $600 if possible.
Can anyone lead me in the right direction?
Old 04-07-2004, 05:52 PM
radio-op is on a distinguished road
Take a look at http://www.cnc-hobby.com/index.html, this site will give you a very good idea of how these machines come together. Enjoy
Bill
Old 04-07-2004, 06:30 PM
bennylaird is on a distinguished road
Same here
I'm in the same boat, just starting to produce electric model aircraft kits, www.laird-electrics.com
Overwelmed with info and need to start building, having trouble sourcing parts downunder though.
Never to old to learn something new!
Old 04-07-2004, 11:08 PM
Nono's Avatar
Nono is on a distinguished road
I would like to build 4 ft pencil boats.. sounds like the machine will be about the same size.. I need a long machine(X) that does not have to be wide (Y) but about 14 inches on the (Z).. I found a supplier localy that has 220Vac servo motors that I am considering using.. I don't find many articles about ac servo motors.
If you have and don't use it, you still have it.
Old 04-07-2004, 11:14 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
Benny, the HP Laserjet printers are popular, all over the world. The LaserJet I, II, and III series all use a 100 oz-in stepper motor that works quite well for small to medium sized homebuilt routers.
Keep your eyes open...lots of stuff shows up on the used and surplus markets.
If you don't mind a small table, you can convert a cross-slide machinist's vise into a screw driven X-Y table. This is available in the States...undoubtedly something comparable is available down by you. I think this one, despite its questionable quality (Chinese origin), is a good CNC platform for a tiny table. It's certainly stiffer than almost anything you could build for the price. The only down sides are: poor quality lead screws that need replacing (13mm ACME, I believe) and tiny capacity at 4x6 inches.
http://www.cumminstools.com/browse.cfm/4,92.html
-- Chuck Knight
Old 04-13-2004, 04:36 PM
So I'm guessing I need to design my own beast, them come back here for answers to component questions....
Old 04-13-2004, 04:54 PM
buscht's Avatar
buscht is on a distinguished road
You don't have to design your own. Here are some plans, you would have to reposition your parts though to get the full 36" cut. Or you might alter the plans.
http://www.hobbycnc.com/plans/plans.htm
Old 04-13-2004, 05:11 PM
I've seen some stuff on CrankOrgans site.... I like his Phoenix design... Has anyone tried that here?
Old 04-13-2004, 05:25 PM
http://www.crankorgan.com/phoenix.htm
I'm also looking at his 4 axis controler.. I like his low cost approach.
Not sure I'm ready for this - I've started building! Mike F CNC Wood Router Project Log 408 02-26-2011 10:26 PM
Started building at last! The Wizard CNC Wood Router Project Log 24 09-05-2007 04:16 AM
Getting Started johnm99 DIY-CNC Router Table Machines 5 11-12-2004 04:59 PM
new to cnc. have about 3k budget, how to get started? Trike General Metal Working Machines 5 06-17-2004 05:05 PM
