  #13
Old 04-08-2004, 01:53 PM
chuckknigh's Avatar
Gold Member
chuckknigh is on a distinguished road
OK, since you've got ball bearings, try this. Take one of those ball bearings (I hope it'll fit around your screw) and put your leadscrew through it. Now, put a nut on either side, to hold it on.
Grab hold of the leadscrew, and the bearing -- now spin.
You've only got to figure out a way to hold the bearing in place. Do a search on this forum for "thrust bearing" and you'll find all sorts of ideas...some simple, some complex.
As for the gantry, make it however high it needs to be. How's that for a useless answer? OK...start by drawing a rough sketch of your router, with dimensions. Now, design a framework to hold it...still on paper. Your gantry clearance should be what it takes to move your router bit from the highest to the lowest point that you need.
It's best decided, by doing the design. Depending on what you intend to do with your router, your clearance could be 1/2 inch, or several feet! For a first machine, a couple of inches is usually enough...lets you put standard plywood and MDF under it, but doesn't complicate the design too much.
-- Chuck Knight
  #14   Ban this user!
Old 04-08-2004, 03:20 PM
Zagroseckt is on a distinguished road
hehe i think i know what your talking about when you say ballberrings but im speeking literly of (the balls)
But i can get some packed berrings i might even have some in a closet ill go look
Lead screw whip spalm DIY-CNC Router Table Machines 3 05-24-2005 02:04 PM
One lead screw off-centered..Will it work? bgolash DIY-CNC Router Table Machines 14 04-02-2005 08:57 AM
Alternate Lead Screw Mounting Idea Jay C Mechanical Calculations/Engineering Design 4 02-20-2005 01:32 PM
How to machine a 56 Rockwell lead screw bgolash General Metalwork Discussion 6 12-05-2004 03:25 AM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 08:49 AM
