Old 05-22-2007, 12:21 AM
geneween is on a distinguished road
Need to locate some things.....
I have recently purchesed a DIY CNC router...I'm planing on using a trim router to cut G10 type material...I was looking for a 3 jaw chuck to fit in a 1/4" collet or some kind of an adapter to make it work so I can use normal drill bits and end mills.
gw
Old 05-22-2007, 10:28 AM
ok, lets try it this way....what would you guys use for a spindle if you wanted to use a 3 Jaw chuck...
Geneween
Old 05-22-2007, 01:51 PM
rustamd is on a distinguished road
I'll be using Hitachi router, which uses collets. Comes with 1/4" and 1/2". I dont see why it would hold drill bits in there?.?.?
Old 05-22-2007, 01:57 PM
Oldmanandhistoy is on a distinguished road
Look at it this way if router spindles where designed for using standard drill bit and end mills there would already be a product out there.
I think the clue is in the router spindles speed range.
John
Old 05-22-2007, 02:00 PM
mine goes down to 8k and up to 24k, dont really see a problem(maybe for drilling with big bits with slow plunge speed???). Keep in mind than i'm not real woodworker, or machinist or anything else
Old 05-22-2007, 02:25 PM
The CNC table I have was designed for a rotozip type tool. For what I want to cut I would really like the freedom to use drill bits and end mills with with diff. shank sizes. the trim routers I've been looking at all have 1/4in collets. I know I can find drill bits and end mils with 1/4 in shanks. it would just be nice to be able to just grab any drill bit or end mill and stick it in a chuck. I found places that have 3 jaw chucks with 1/2in staight shanks and that would fit perfect in a full size router, but I don't think my table and motors could take the weight of a full size...
Geneween
Old 05-23-2007, 01:55 AM
vger's Avatar
vger is on a distinguished road
Danger
The speed of the spindle will be the danger... the 3 jaw chuck will be large enough and most likely out of balance enough that it will at very least bend the 1/4 " shank stuck in the router and most likely break and send the chuck flying at great velocity and inertia in a random direction.
Voice of experience.
Steve
Old 05-23-2007, 11:04 AM
Steve thanks for your concern...I have a speed control for the trim router so I can slow i down to a min. of 600 RPM and it has an upper limit in the 25K range...it's a homemade trim router I found online....
Geneween
Purchasing CNC VMC things to consider? skyline General Metalwork Discussion 19 11-21-2006 04:06 PM
need help with a few things. BeeleJuice Bridgeport and Hardinge Mills 2 08-02-2006 11:32 PM
Things to cut joecnc2006 DIY-CNC Router Table Machines 18 06-29-2005 05:20 PM
