Old 05-18-2007, 05:23 PM
ringram2077 is on a distinguished road
Cut a concave trough with a cnc router ?
Newbie question - Can this be done ? Trying to think how you would make a 2d drawing to do this. Or maybe you would model it. I want to cut the trough (say a half circle) in the xy plane.
Old 05-18-2007, 10:23 PM
BSims66173 is on a distinguished road
I also would like to know how to cut a concave. Trying to figure out how to make a highchair tray for my grandaughter.
Old 05-18-2007, 10:38 PM
ger21's Avatar
Just draw a series of lines to clean out the area. The distance between the lines depends on the size of the bit, and how much you want to clean up afterward. Or use a flat bottom tool to clean out most of the material, and a ballnose tool to add the radius around the edges.
Old 05-18-2007, 10:40 PM
SORCHEROR is on a distinguished road
im not sure what you guys want to cut?you mean like cut a half circle dish or bowl?what software you have to draw it in?the easy way to cut the highchair tray would be to pocket it out and use a form cutter,basic 2d tool path than
Old 05-19-2007, 01:33 AM
wcarrothers1 is on a distinguished road
This sounds like something you would want to use 3Dcut to generate a tool path. same people that make vcarve..
Least that is the way I would do it.
b.
Old 05-19-2007, 06:54 AM
Jason Marsha is on a distinguished road
oops!
Old 05-19-2007, 09:01 AM
The only software I have is Alibre for modeling and 2D drawing. I want to cut a half round slot in wood, like it you took a plunge router with a round cutter and dropped it in the middle of the piece and slid it a couple of inches. The difference would be at the start and end of the cut it would be more square that round like the plunge router would do. Hope this description makes some sense.
Old 05-19-2007, 09:13 AM
ger21's Avatar
A slot with square corners?
Old 05-19-2007, 09:53 AM
cyclestart is on a distinguished road
Do you mean the type of slot created by a woodruff keyseat cutter? If someone knows how to create that by plunging I would love to hear the explanation also.
Edit/ If I guessed right about the woodruff style slot, can you live with some rounding of the edges? Warning: woodworking is not my thing.
Old 05-19-2007, 10:35 AM
Yes I think the woodruff key is what I am describing. I am attempting to attach a model I what I want to do.
Old 05-19-2007, 10:45 AM
ger21's Avatar
Attempting that with a 2D drawing would be extremely difficult, although it could be done with a lot of layers and a lot of calculations. Your best bet would be to export an .stl and use a 3D CAM program.
  #12   Ban this user!
Old 05-19-2007, 06:17 PM
OK, thanks for the help. Guess I'll need to scrape up some new software.
Error - Concave corner with cutter... MichaelHenry Mach Mill 5 02-06-2007 10:20 AM
turning a concave shape krymis Mini Lathe 0 12-11-2006 02:15 PM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 04:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 01:27 PM
