  #25
Old 05-21-2007, 08:02 AM
ger21's Avatar
It looks fine here. What kind of problem are you seeing?
  #26   Ban this user!
Old 05-21-2007, 08:37 AM
ringram2077 is on a distinguished road
The tool path does not even resemble what I want. I must be setting it up all wrong. Funny I got Freemill to make a perfect tool path before it started locking up.
  #27   Ban this user!
Old 05-21-2007, 04:24 PM
When you say it looks fine do you mean the toolpath in Meshcam looks fine ? I just don't see what I could be doing that wrong in Meshcam. However I am quite capable of screwing up in a big way. If you can make a nc file please let me see what it looks like.
  #28   Ban this user!
Old 05-21-2007, 06:47 PM
js11110 is on a distinguished road
Cut3D from vectric.com will do this no problem as long as you have a model. Check it out.
Jason
Everytime you think you made something idiot-proof, they keep making new and approved idiots.
Old 05-21-2007, 07:24 PM
ger21's Avatar
Here's a pic from MeshCAM, Mach3, and the code. There's no roughing pass, just a finish pass with a 1/4" ballnose tool.
ID:	37755   Click image for larger version
  #30   Ban this user!
Old 05-22-2007, 09:07 AM
Jason
Cut3D does work for me. Too bad it won't make the post code (demo version crippled). Worked very easily.
Thanks for the files. I wish I new what I was doing wrong in Meshcam. I'll try again and maybe describe how I step through the program.
Update:
I went back and did the same process except I only used a finishing pass as you said and it worked perfectly !!
  #31   Ban this user!
Old 05-23-2007, 12:55 PM
I got a call from Mecsoft asking about FreeMill and how it was working. I told the gut it started locking up and would not work He said to turn of (set to none) the acceleration on the display card. I tried it and it worked. No more locking up. Thought maybe someone else might want to know about this.
Error - Concave corner with cutter... MichaelHenry Mach Mill 5 02-06-2007 09:20 AM
turning a concave shape krymis Mini Lathe 0 12-11-2006 01:15 PM
Using a router for the 1st time. Need advice of cut speeds, router bits etc. Apples DIY-CNC Router Table Machines 19 09-23-2006 03:33 PM
Surfcam PP for Isel router / Precix router IvanTochev Post Processor Files 2 05-12-2004 12:27 PM
