Old 05-16-2007, 10:47 AM
scratch_6057 is on a distinguished road
MICRO Adjustment of Lever Type Limit Switch
oops double post
Mike_L
When I was younger I thought I knew EVERYTHING,
NOW, the older I get the more I find out I don’t know!
Old 05-16-2007, 06:15 PM
rustamd is on a distinguished road
you edited out both of your posts, so now both of them have no info on what you wanted to post
Old 05-16-2007, 09:19 PM
Now it's back
I arranged a MICRO adjustment screw adaptor for limit switches on a
project I was working on, I'll try to explain in words (my
replacement camera is being shipped to me).
For each limit switch the adaptor requires 1 - Female wire to spade
lug terminal connector, 1 - 4/40 screw, 2 – 4/40 nuts, glue / solder
braze.
Remove any plastic insulation on the connector. Open up and flatten
out the `barrel' of the terminal connector (where the wire would
normally be inserted).
In the center of that flattened section drill a hole that the screw
will just fit thru without having to thread the screw into the metal.
Thread one nut onto the screw about half way down the length.
Pass the screw thru the hole in the flattened `barrel' and secure
with the second nut.
The connector now fits onto the `Lever ` of the switch as it would
normally fit the male electrical connector. The threaded end of the
screw points towards the MOVING part table, carriage, etc.
When you have the positioning you want, consider (silver) soldering,
brazing or gluing the modified terminal connector to the lever of the
switch. If you glue you might consider drilling a hole thru the
connector and switch lever, glues to use would be Hot-Melt and Epoxy.
Use the nuts locked against either side of the flattened section of
the connector, and each other to hold the screw at it's adjustment
point. As for the screws, I've found the easiest thing for me is a
socket head and a 90 deg. Allen wrench.
Some sort of audible continuity meter (or beeper / buzzer & battery)
connected to the switches can be helpful for exact adjustment.
Mike_L
MICRO Adjustment of Lever Type Limit Switch scratch_6057 DIY-CNC Router Table Machines 0 05-16-2007 09:47 AM
limit switch and home switch setup Runner4404spd General Electronics Discussion 0 12-15-2005 08:58 AM
Is it possible to use the home switch as the limit switch as well? Darc Mach Software (ArtSoft software) 2 10-23-2005 01:50 AM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 06:58 PM
