Old 05-15-2007, 04:58 PM
bigz1's Avatar
bigz1 is on a distinguished road
Cheap Quick change router collet?
I saw this after looking at various quick change router collets.
http://www.amazon.com/Skil-1845-02-H.../dp/B0000302RA
Unfortunately its unavailable this side of water. Has anyone used it?
Old 05-15-2007, 06:37 PM
Oldmanandhistoy is on a distinguished road
Hi Bigz1,
Never heard of this quick change collet before sounds interesting; I would like to have a close up to see how it works or a description form some one who has one.
I am at the moment buying up cheap Kress routers so I can leave the cutter in each one and just quick change the spindle instead. Will look into a tool changer in the future but for now it works fine for lighter work with the 900W Kress routers.
John
Old 05-15-2007, 06:42 PM
bigz1's Avatar
John have you seen this yet.
Two more of Joe's CNC Model 2006
http://www.hightechsystemsllc.com/in...s/Page2045.htm
If only my wallet was deep enough.
Old 05-15-2007, 06:48 PM
If you are referring to the tool changer yes I have. Down side to the system is the fact that it is limited to 10 000 rpm and I need the speed (I like speed ). Thanks for the time pointing it out though.
John
Old 05-15-2007, 06:53 PM
bigz1's Avatar
It would be OK with my present feedrate at a MAX of 100" per min. But if I eventually double the speed going 3 flute on the cutters would get round the RPM problem(if it is a problem?).
Old 05-15-2007, 06:57 PM
I have cutting speeds at present of 6m/min on my X axis and will be upgrading my Y to keep up very soon so for me 10 000rpm just would not be quick enough.
John
Old 05-15-2007, 07:14 PM
bigz1's Avatar
You can buy the collet seperately!!!
http://www.woodworking.org/WC/GArchi...wercollet.html
Old 05-15-2007, 07:29 PM
Found these two on Ebay may be more; I will be looking into these more when I get a min.
http://cgi.ebay.com/JACOBS-QUICK-CHA...QQcmdZViewItem
Thanks for the link
John
Old 05-15-2007, 07:57 PM
I have just read that the Jacobs chuck has been discontinued on a forum?
http://www.ukworkshop.co.uk/forums/v...27bd585f12a10b
Any one got more information?
John
Precision Quick change collet Set thackman Syil Products 13 03-22-2007 04:07 PM
Quick change collet MagTDK DIY-CNC Router Table Machines 4 09-08-2006 04:08 PM
quick change R-8? replicapro Benchtop Machines 10 04-14-2006 11:00 AM
Quick tool change Biggermens CNCzone Club House 5 02-02-2006 12:36 AM
Quick change router bit wjbzone DIY-CNC Router Table Machines 13 06-07-2005 01:56 PM
