  #13   Ban this user!
Old 05-16-2007, 04:58 PM
low_48 is on a distinguished road
I think a different chose of router bits would eliminate the plastic melting. Use a Onsrud c flute for plastic. You won't believe how clean they cut. You may check on recommended speeds, but they should work alot better.
  #14   Ban this user!
Old 05-16-2007, 05:14 PM
dwacker is on a distinguished road
Those are what I'm using. I can get a clean cut at about 12K max but thats with my regular router that has a speed control. Unfortunatly the rigid will not go below 20K.
Don
  #15   Ban this user!
Old 05-16-2007, 06:58 PM
Oldmanandhistoy is on a distinguished road
I still think that ger21’s idea is good to go and when I get the time I will have a go.
John
Old 05-16-2007, 08:15 PM
ger21's Avatar
I'd buy Arturo's ready to run solution rather than build it from scratch.
  #17   Ban this user!
Old 05-21-2007, 02:10 PM
I got this one figured out. Called onsrud hoping for another bit that would cure the problem. They suggested the same bit and that my thinking was backwards. I ran the speed up to 30K and am getting great cuts.
Thanks for all the suggestions
Don
Speed control ? deleteallusers G-Code Programing 3 05-10-2007 01:48 PM
BPSeriesI / Centroid control- Spindle speed all out of whack with speed dial? peter.blais Bridgeport and Hardinge Mills 9 08-08-2006 03:29 AM
PIC R/C speed control? DennisCNC PIC Programing / Design 1 04-01-2006 01:22 AM
Router speed control ljoe1969 General Electronics Discussion 4 08-01-2005 08:13 AM
AC Speed Control georgebarr General Electronics Discussion 7 01-06-2004 07:33 PM
