Most of the machines I have seen have sufficient depth and not enough length. A 4'x8' foot machine would be too big for my shop. My question is; Is it possible to route one section of a panel and move the work down and finish the next section? Thanks to all who reply. Daniel |
That is what I was thinking. For none production work of one off designs. Setting the cut to end and start again at a fixed point seems resonable. Rather then have a large system bigger taking up tons of space. Thanks for your reply. Daniel |
| I am struggling with this problem as well, but perhaps even more so for my small garage area. At most, 2 x 4 ft available, x 7 ft high total. The crazy idea I am playing with is to build the long axis vertically, so essentially setting the whole thing on end. For milling a full sheet, I am wondering about feeding the sheet in from one side, locating 2 holes with a pin of some kind, and maybe screwing down the sheet to the back wall / table as needed. Still toying with how to pull this off, but maybe using a cabinet like design made from 2 in wall honeycomb panels and an Al channel frame. |
It is possible, I have done with table saws, drill presses, etc. but the largest problem is the realignment and recalibration of your part to the machine. In my experience even the most well thought out process introduces errors, mostly small, some large. I think you would be better off machining two separate parts then joining them back together. But in a pinch, you what it take to get the desired result... |
| Tracker CNC plasma cutting machines | AdvanTech | CNC Plasma and Waterjet Machines | 44 | 05-31-2011 11:06 AM |
| Velocity vs pressure with die cutting machines | team08 | Diemaking and Diecutting | 3 | 01-10-2008 11:33 AM |
| Communitie at Orkut about cutting machines | Alex S.A | CNC Plasma and Waterjet Machines | 0 | 02-05-2006 08:22 AM |
| MDF with Plywood | spalm | WoodWorking | 14 | 11-14-2005 06:45 PM |
| Plywood as tooling?!? | DAB_Design | Work Fixtures and Hold-Down Solutions | 9 | 09-26-2005 04:11 PM |
