Well i have been building my router since yesterday and just got the gantry up and secured. Im basing a lot of the mods to the design off of Don's router, since i like how it will save some time in building and by doubling up on the gantry support brace the router is rock solid. I am keeping a blog on the build of the machine. http://max-wilson.com/category/blog/cnc-machine/ Here is what it looks like as of posting this: |
| Ok well im calling it a night, i just got the X axis test fited and its very smooth. You might notice that im not using the 4 supporting blocks on the end, thats because when i made the gantry sides i made them screwed together so they are 100% identical. And it eneded up fitting with just some minor sanding to the z-x plate as expected. I only have 3 clamps so i am going to have to buy a few more tomorrow after work, and hopefully i will get the z and y mounted tomorrow. |
| Well i made the cutting area 18 x 18" so the base is 12" longer then the design in the manual. I just got all 3 motors mounted tonight and all the rest of the parts needed to be glued, so if all goes well tomorrow i will get this baby runing... |
| After running into some wiring issues causing one axis not to move i got the machine running, but unfortunately the 1/4" 20 rod wobbles to much and ripped the y axis nut out. And the motors would stall at 20 IPM. So i just ordered some 1/2 10 acme rod, Flexible Spider Shaft Coupling and bearings to do the setup the right way. Lucky McMaster has everything in-stock at los angeles so im gona drive over and pick it all up. So i hope to get it converted to acme by the end of tomorrow, since i am staying home from work to get the machine done. I will post up some photos and video once its running. |
| Just installed the y axis today and got the machine fully working. I dropped the y stepper so its damaged and stalls over 15 IPM, so i ordered a new stepper. But at least i can get the machine working and start learing the software. The cnc is fully assembled!!! I did jog all the axis and they are very smooth. |
#10
| Hi how do you find the bronze bearings with the steel rod ?? are they a smooth ride on all axis and what sizes are you using for the X,Y and Z ?? and also how do you fix the bronze bearing into the MDF this is baffling me as I am definately going to go with your route as its reasonably priced here in the UK but before I cough up the money would like your advice on this, and by the way that is a superb looking machine!! What are the actual cutting dimensions of your machine. I am torn between a moving gantry or your design cant decide any pointers on whats swing and roundabouts with either machine ? |
#12
| I just wedged them in and glued them in place, seems to work good and it is extremely smooth. I should have 18x18x5 cutting area. I was looking at a moving gantry design but i just didn't think i could make it all line up, so thats why i went with this design. Its actually a really nice design, i just had to complicate it by going to acme and using 3/4" rod so i had to change the design a bit. haha yea i wanted to get it done fast, i have about 2 full days, 2 half days and a few nights on the machine. |
| Possible to lengthen the y on Rockliff Router? | rcflybry | DIY-CNC Router Table Machines | 1 | 02-13-2007 07:59 PM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
