Old 04-04-2004, 04:00 AM
cbcnc is on a distinguished road
Here's My Router
I have had a couple of requests to post the specs and details of my router. It has definately been a learning experience and a year long project. Alot of the parts are surplus.
Construction: Birch Plywood, MDF, Steel and Aluminum.
Configuration: X Axis Rolling Gantry.
Overall Size: 22w x 46L x 28h.
Cutting Area: 30" x 14" x 5".
Spindle: Porter Cable Trim Router and Manual Speed Control. 1/4" and 1/8" collets.
Linear Bearings and Ways: X Axis - Skate Bearings and Supported 1" Black Pipe.
Y and Z Axes - Oilite Bronze Bearings and 3/4" Cold Rolled Steel Shafts.
Leadscrews and Nuts: 1/2" - 10 tpi Acme Threaded Rod. Delrin Antibacklash Nuts.
Stepper Motors: Vexta 6v, 1.2a.
Controller: John Kleinbauer Piker 4X. Resistors for Current Regulation.
Power Supply: 24v, 24a Switching Supply. Regulated 5v for Electronics.
Computer: Pentium 150 mhz. Dual Boot, Windows NTand Dos 6.22. Networked in Windows. TurboCnc 3.24c.
Cost: Hard to say as I have a full junkbox. Under $300 out of pocket.
Plans: In my head. No copies available.
I'll write more later and show you some construction pics.
Chris
Old 04-04-2004, 04:19 AM
ynneb's Avatar
Moderator
ynneb is on a distinguished road
Thats a nice looking job youve done there. I was wondering if you could post a picture of something it has cut.
How long did it take to make?
I didnt think it was possible to put NT on a pentium 150. Ive learnt something.
Are you pleased with its perfromance?
Old 04-04-2004, 08:47 AM
ger21's Avatar
When I first bought NT4, It was not long after I bought a "top of the line" Pentium 166. I paid $1200 for the processor alone, as it was about the fastest available at that time. I still use NT4 at work on a 750. Its a bit quicker than Win2K, and uses about 50% less memory, if you can deal with it's limitations (no USB).
Old 04-04-2004, 01:51 PM
Here is a pic of the X gantry under construction:
The gantry was built out of 3/4" steel L angle. Lapped over on the ends. Bolted w/ 1 bolt in the corners and a plywood insert set in to stiffen it up.
The X axis bearings were bolted to the angle iron frame with standoffs to bring them to the center of the pipe rails.
Since the base is 46" long 1" pipe would sag too much so I put them on supports and built the base strong enough support it all.
I don't have a pic of the framework under it all but there is alot pieces to the frame and it is all glued and screwed together.
The computer came from my wifes work as they had grown out of it. At some point it was state of the art. They used it for scientific imaging so it had alot of memory for it's time.
Chris
Old 04-04-2004, 02:28 PM
radio-op is on a distinguished road
Very nice! I really like your X axis design. How did you attach the pipe to the support rail?
Have you had any issues with keeping the gantry on the X axis? I had thought about doing the same arrangment, but I was concerned because the bearings being on top and on a side didn't capture around the pipe. Could a lever action from the cutting bit and the fixed table translate to a lifting force at the X axis rails?
Very nice Chris!
Bill
Old 04-04-2004, 03:29 PM
You are right. There isn't really anything holding the gantry down other than the leadscrew and gravity. On the other hand the router wasn't meant to mill steel. I haven't noticed any problem on the parts that I have cut.
The pipe rails are bolted thru the base and the support. I used 1/4" bolts but I think a larger size would be better. Since the pipe is soft the threads can strip out.
Chris
Old 04-04-2004, 09:54 PM
Well, if it aint broke don't fix it You really did a nice job on the router!
Bill
Old 04-05-2004, 10:47 AM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
cbnc - Chris - thanks for all that! I'll add your data to the spreadsheet I'm organizing (wanna replace the data call in the Tech Section - How-Tos).
All that info is very helpful to anybody trying to figure out what to do next when getting started. Great job too!
cheers - Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 04-06-2004, 06:55 PM
natchez is on a distinguished road
cnc
if the rail on your x axis was solid steel would you still need the support
Old 04-06-2004, 07:55 PM
mvaughn's Avatar
Moderator
mvaughn is on a distinguished road
1 inch steel rails spanning 46 inches would likely have some noticable deflection.
CBCNC,
Thanks for posting the specs on your machine. I'm currently drawing up some plans for my machine in progress. I am most likely going to adopt several aspects of your design. Specifically the X-axis rail design, and the table w/steel supports.
  #11   Ban this user!
Old 04-07-2004, 02:39 AM
Ahh, the cutting table. When I first planned it I was thinking of MDF spanning the 44 1/2" with 3/4" angle iron on the outside edges. Well after cutting the iron into the MDF and trying it out, it was too bouncy. So I went to the local scrapyard and bought 20' of 1" square, 1/8" wall, tubing. 4 pieces of that and the table with a 22 lb. weight sags about 12 thou. That's good enough for this router and what I'll be cutting.
Oh yeah, since I didn't want screws up into my cutting table I glued the tubing to the MDF with Liquid Nails.
Chris
  #12   Ban this user!
Old 04-07-2004, 03:08 AM
Shortcomings on my design:
You might as well build a steel frame for the cutting table to sit on. I only had 1" to work with and thicker tubing would be better. Like maybe 1 1/2" x 1".
The gantry is only held down by gravity. So linear bearings that held the gantry down would be better.
Use 5/16 or 3/8" bolts to bolt to the Black pipe.
80 oz. motors are just barely strong enough. I find that I can stall an axis fairly easily.
Use shielded cable to wire your motors and switches. I found that my Porter Cable Trimmer put out alot of RFI and caused the steppers to noticably jump when I turned it on.
Have Fun,
Chris
Techno-Isel CNC router for sale? Noah Commercial CNC Wood Routers 5 11-27-2008 11:12 PM
Finding The Right Router Crushmonkey Commercial CNC Wood Routers 22 06-19-2006 02:17 AM
Quick built router CNC Darren DIY-CNC Router Table Machines 10 06-05-2005 09:09 PM
long term stability of wood framed router dave925 DIY-CNC Router Table Machines 17 05-06-2005 12:33 AM
my new longbed router cncspear DIY-CNC Router Table Machines 16 10-15-2004 09:36 PM
