04-07-2004, 01:39 PM
 | Moderator | | Join Date: Jan 2004 Location: United States Age: 33
Originally posted by cbcnc Ahh, the cutting table. When I first planned it I was thinking of MDF spanning the 44 1/2" with 3/4" angle iron on the outside edges. Well after cutting the iron into the MDF and trying it out, it was too bouncy. So I went to the local scrapyard and bought 20' of 1" square, 1/8" wall, tubing. 4 pieces of that and the table with a 22 lb. weight sags about 12 thou. That's good enough for this router and what I'll be cutting.
Oh yeah, since I didn't want screws up into my cutting table I glued the tubing to the MDF with Liquid Nails.
Chris |
One thing that I haven't seen done yet is providing support for the table via bearings mounted inverted on the gantry. If your gantry is stiff enough your could mount some rollerblade bearings on the top of the gantry losswer crossmember. the bearings would ride along the 1inch square steel tubing. This way if you had a saggy table it would be lifted to the correct height as the gantry slides under it. |
