Old 04-04-2004, 12:36 AM
radio-op is on a distinguished road
My first
Hi all,
Well, I'm kind of new around here, been lurking for months. The great machines here has inspired me to build my own. So here are the specs:
Moving gantry, 48 x 32 table
34 x 24 x 5.5 envelope, Porter-Cable 1 3/4HP router.
3 214oz/in Pac Sci Powermax II driving 1/2 10 Acme lead screws with Delrin AB nuts.
3 Embeddedtronic microstepping chopper drives running the steppers in series bipolar.
30A 30V PSU (3 10A 24VAC frame transformers, 1 per motor).
Igus Drylin W40 doubles for the X axis, rollerblade bearings and harden 1" shafts for the Y, W singles at 6" apart for the Z.
The gantry is built of 1010 and 1020 X beams from 8020, with 1/8" alum gusset plates.
Don't beat me up too much, but my camera is C*&p! Don't stare too long or you'll go blind. that said, here are some Pixs.
Name:	gantry and router.jpg‎
Old 04-04-2004, 12:39 AM
Next pix
Here is the back of the Y axis carriage. rollerblade bearings on harden 1" shaft. No lead screw yet.
Name:	y axis back.jpg‎
Old 04-04-2004, 12:57 AM
Here is the shaft mount. 1/2" PVC
Name:	shaft mount.jpg‎
Old 04-04-2004, 01:02 AM
The front of the Z axis. The Drylin bearings were a sample I requested 12" of W40mm, then cut down the middle and mounted 6" apart. Had to build up the height between the Z back plate and the spindle mounting plate to make room for the lead screw. used 1" x .375" flat bar.
Name:	z axis close.jpg‎
Old 04-04-2004, 01:06 AM
Here is the Z axis with the router mounted.
Name:	z axis router mount.jpg‎
Old 04-04-2004, 01:08 AM
this is the top of the Z, awaiting the stepper mount.
Name:	z axis drylin and motor mount.jpg‎
Old 04-04-2004, 01:10 AM
Here is a view of the gantry frame
Name:	gantry inside 2.jpg‎
Old 04-04-2004, 01:15 AM
Here is the PSU. a 10A transformer per axis. It's built in a old PC case. The drivers will mount on the other side by the drive bay.
Name:	psu transformers.jpg‎
Old 04-04-2004, 01:23 AM
I've been ordering parts for about a month, Enco and McMaster-Carr knows my shipping address well I've been building for about 2 weeks now, working from the Z down. I hope to spin up my Z stepper by next weekend. More to follow!
Bill
Name:	gantry w router.jpg‎
Old 04-04-2004, 08:41 AM
ger21's Avatar
Do the 1" y-axis shafts deflect at all? To me that seems to be the biggest problem with both the rollerblade bearing designs, and the Thompson style unsupported linear bearings.
  #11   Ban this user!
Old 04-04-2004, 01:57 PM
I haven't checked with a dial indicator, but it doen't seem to. To tell the truth that was the first axis I built and if I were to start over I would use the Drylin system. It works well so I'll leave it for now.
Bill
  #12   Ban this user!
Old 04-04-2004, 02:18 PM
vacpress is on a distinguished road
awww. jealousy.. cant wait till i get there...
my 40" Y axis linear bearing is in the mail... now i just need another zillion dollars of high end linear components, and ill be set.
keep te pics comming!
Design & Development
My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info
