#49
| Yeah, if I had a metal lathe, I'd definately try to make the rollers, and buy the rail. At $20+ each, they add up fast.
#50
| i have a lathe, just no experience turning parts.. i havent had it long. i use it alot to make couplers and to true parts, etc. nothing much. i bout the lathe used with lots of tooling. anyone got any specific advice on what setups to use to make a vflange style bearing like in my first images? id image some kind of carbide facing cutter to machine the outside diameter true? then using a v-cutter carbide tool to make the V? ive got lots of tools i dont know the names of -different lathe cutters.
__________________ Design & Development My Portfolio: www.robertguyser.com | CAD Blog I Contribute to: http://www.jeffcad.info |
#51
| Teilhardo...reading one of the posts from the first page. A V shape can be less tolerent to fit the same shape. In other words...it could roll on angle iron, strap steel, or round stock. I am going to turn down some old skatboard wheels, and see it that works. You can usually get skateboards cheap at garage sales, thrift stores, etc.
__________________ Stop talking about it and do it already!!!!! (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#52
Doug |
#53
| I am currently using UHMW with 1 1/2" cold rolled polished with 600grit wet/dry sand paper (wet) and it seems to be holding up really well. I cut the blocks on a high quality table saw and drilled them with an 1 1/2" forstner bit on my drill press. Then drilled (6) 3/8" half moon reliefs about the perimitter and use silicone spray as a lubricant. Got to say it has been working great with no signs of wear at all. 4' of cold rolled cost me $20 .00 . Originally this was just a temporary setup and I was going to replace them with some wheels that I turned out of aluminum with abec 7 bearing inserts but it has worked so well that I never had to change them. It's been over 2 years. I use my router to carve signs and craft projects for our country gift shop. Last edited by tpworks; 04-17-2004 at 08:38 PM. |
#58
| I must be extra dense tonight "Then drilled 6 3/8" half moon reliefs about the perimitter and use silicone spray as a lubricant. " I'm not picturing this- these are perpendicular to the axis of the cold rolled? drilled yet "half moon"? help...
__________________ maybe... |
#59
| Drilled parallel to the shaft to reduce friction by reducing the bearing surface, and then spray the shaft and let dry , slicker than grease. I moved the carriage effortlessly with one finger before the screw was in place. Last edited by tpworks; 04-17-2004 at 08:42 PM. |
| gas pipe & linear bearing dimensions relationship | zoltan | Linear and Rotary Motion | 6 | 06-13-2005 03:12 PM |
| Linear Bearing mat’l? | jakk100 | Linear and Rotary Motion | 19 | 05-18-2005 12:15 PM |
| a cheap linear bearing | mocnc | DIY-CNC Router Table Machines | 8 | 03-26-2005 04:52 PM |
| Linear bearing spacing & Sizing linear rails? | fyffe555 | DIY-CNC Router Table Machines | 3 | 12-07-2004 01:09 PM |
| build your own linear bearing | CNC Brute | DIY-CNC Router Table Machines | 4 | 02-07-2004 03:32 AM |
