Old 05-02-2007, 02:59 PM
scratch_6057 is on a distinguished road
The Ultimate CHEAP Wooden Linear Slide & other Rambelings
OK, I really haven't had anything to say lately so
I’ve been keeping my mouth shut.
I keep seeing this
"Hello scratch_6057 it appears that you have not posted
on our forums in several weeks, why not take a few moments
to ask a question, help provide a solution or just engage
in a conversation with another member in any one of our forums?"
SO, I'll post something even though I STILL really don't have
ANYTHING to say.
http://www.rockler.com/product.cfm?page=198&cs=1
With enough coats of something THICK to seal it and take the
slop pot and then LOTS of sanding / finish work, someone may
find it usable on a VERY basic Entry Level machine. Might
actually be useful to someone who is just wanting to sample
what CNC is all about, I wonder if they would work with NEMA 17
Floppy Drive steppers?
On a slightly more serious note, I know it’s been brought up on the Zone
from time to time but I’ve never really seen a positive response (if there are any).
So I’ll ask again (please don’t SHOOT ME, or run me off). "Has anyone done any
work with HDPE / UHMW Plastic for supported slides?" I came across some
0.125 Wall UHMW ‘U’ or ‘C’ Channel on mcmaster.com Part Number:8672K31
Leg Length 3/4" (Height) Outside, Base Length 1-1/4" (Width) Given
the above measurements the inside of the channel should be 5/8 (height) by 3/4 (wide).
Seems to me that could be mounted to a base (counter sunk screws thru the bottom)
for guide ways then use 3/4 by ??? HDPE or UHMW for the rails attached to a table.
The Channel Costs $2.04 (8 Ft & up) - $2.36 per ft. (2 - 7 ft)
3/4" By 1" for rails is
High-Density Polyethylene (HDPE) 8671K15 $1.66 per Ft.
Ultra-High Molecular Weight Polyethylene (UHMW) 8702K112 3.08 per Ft.
(FYI HDPE on HPDE slides rather well, almost as good as fresh 'Dog Squat' in the yard)
I got my copy of the Rockcliff plans a couple of days ago, that’s what got me
thinking in this direction.
Mike_L
When I was younger I thought I knew EVERYTHING,
NOW, the older I get the more I find out I don’t know!
Old 05-02-2007, 05:23 PM
Moderator
bp092 is on a distinguished road
Linear wood rails? How could you ever compensate for expansion and contraction? It doesn't matter if you dip the thing in a thick epoxy, it will expand and contract depending on moisture/temperature changes no matter what. Even if its a cheap machine it probably wouldn't even be good enough for that.
Old 05-02-2007, 06:01 PM
pminmo's Avatar
pminmo is on a distinguished road
UMHW is used for bearings against polosed/smooth metal surfaces as is acetel. Look at 8020's bearings. It does wear, so if the surface is not polished it will wear more quickly.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Linear Slide jsage Open Source CNC Machine Designs 4 01-30-2007 07:48 AM
Which control should I use for this linear slide? Enzo Linear and Rotary Motion 4 11-19-2006 02:43 AM
Linear Slide Assemply. Smackre Linear and Rotary Motion 0 04-18-2006 10:26 AM
linear slide idea noid DIY-CNC Router Table Machines 16 07-20-2005 10:31 PM
Linear Slide Covers freak_brain CNC Plasma and Waterjet Machines 7 05-02-2005 09:02 AM
