Old 05-01-2007, 09:44 PM
9xnet is on a distinguished road
1/4 - 20 generic vs acme?
I am building a Rockcliff Router and am wondering what the diference is between generic 1/4 20 treaded rod is and the acme rod?
I do you think 5/8th is enough for the x y z rods? i will be making the cnc 18 x 18 cutting area vs the 12 x 12 base design.
Thanks for all your help.
Old 05-02-2007, 09:39 AM
rockcliff's Avatar
rockcliff is on a distinguished road
Hi
1/4-20 is about as fine of a thread pitch as you would want to use, 20 threads per inch will give approx 20 to 25 inches per minute running speed, and about 18 lbs of force with a 200ozin motor. Using an acme thread can give higher travel speeds as the thread pitch can be more coarse, using a more coarse pitch will also lower the amount of force to the slide, your project size of 18 x 18 is only 6 above base model , there will be some flex in any unsupported rail setup, but the amount will be acceptable for cutting softer materials like wood or plastic, for a 5/8 shaft, you can increase the size to 3/4 if you want a little more strength and want to stay with the base model design see don's machine http://www.cnczone.com/forums/showth...ight=rockcliff he used 3/4 on the y axis and 5/8 on the x and z Another possible combination is to use 3/4 on X and Y and to use 1/2 on Z But if your planning to cut harder materials see the commercial bearing model or the DIY slide. hope that helps
Nick
http://www.rockcliffmachine.com
Old 05-03-2007, 10:38 AM
Ok cool, i guess i will go for the acme.
Heres another question, since you say the rods will flex under harder materials why cant i put bearings under the y table that would just ride against the wood under it? would that not support it enough?
Old 05-03-2007, 08:32 PM
rockcliff's Avatar
Post
The 5/8 unsupported shaft will be acceptable for cutting most materials, if you want a more rigid machine build version D see drawing set D1 to D10
Old 05-06-2007, 10:03 AM
one last question before i send my order off.
I have been looking at
6061K447
Hardened Precision Steel Shaft 3/4" OD
It costs a bit more money then the ones in the plan but i was wondering if thats becuase its stonger?
Edit: I wonder if im over engineering this as its my first cnc router?
Old 05-06-2007, 11:55 AM
rockcliff's Avatar
Hi
Hardened shaft will give a very small amount of extra strengh, over un-hardened it should only be used for use with linear ball bearings, I would not recommend it with bronze bearings, unless you wanted to use linear bearings in the future, also with hardened shaft you cannot cut it with a bandsaw or hacksaw you will need to use an abrasive cut off wheel
Wiring Diagram for Generic Breakout board, home and Limit Switches, Generic Drives. CJL5585 Open Source CNC Machine Designs 33 02-24-2010 03:39 PM
Need help with Mastercam v9.1 generic mill post (mpfan) g54-s gasho Post Processor Files 3 07-09-2007 02:39 PM
Need someone to edit generic MPFAN 9 CApostman Post Processors for MC 6 04-14-2007 10:02 AM
Acme Internal Thread 1 ½ - 0.250P-2.000L-ACME-2G-LH (8 START) Help pandiyan.innova CNCzone Club House 7 11-16-2006 05:47 AM
Generic(cheap) Encoder Source mikkojay Servo Motors and Drives 25 04-01-2006 03:27 PM
