Old 03-31-2004, 09:30 PM
jdebuck's Avatar
Gold Member
jdebuck is on a distinguished road
180 oz Stepper Question?
Which of these two stepper motor manufacturers is the better of the two?
Superior Electric Slo-Syn M091-FD-09 (also 440) or ASTROSYN 34PM-C049
Both units above 1.7vdc 4.7a 200 step Nema 34's and are unipolar. I am considering the purchase of one brand or the other for my first cnc project. I'm looking to build a 2'x4' steel gantry / table.
Will these be sufficient for this? (Geckodrives)
I would apprieciate any input...
Thanks!
Jeff
Old 04-02-2004, 01:51 PM
radio-op is on a distinguished road
Don't have any hands on with either motor. Try a Google for the companies. The specs being the same, I would expect the toque to be close on both. All other thing being the same look at the bearings, balls or bronze sleeves. Then its down to the cost. If they cost the same, roll dice.
As far as 'will they work'; depends on the table construction. The better you build it the better it will work. 180 oz/in I would consider for a small/medium size table, but what are you hoping to do with the table? Milling 1/2" alum and 1/2" balsa are night and day.
Bill
Stepper Question ignatz Stepper Motors and Drives 5 04-23-2005 05:26 AM
Stepper Motor Question Dman Servo Motors and Drives 2 01-15-2005 10:55 PM
Stepper Motor Question bcromwell General Electronics Discussion 3 08-31-2004 03:42 PM
Stepper motor spec' source & question Damachine DIY-CNC Router Table Machines 4 04-06-2004 02:01 PM
AC stepper motor question flybynight General Electronics Discussion 1 01-20-2004 06:47 PM
