| Yes they are similar and English is a difficult language. Routing is normally refering to the use of a router and is cutting a trench or full thickness of the material. Engraving is normally on the surface and is often using a low powered spindle. Common engravings are pictures or letters. Carving is a 3 dimentional process. can refer to deep cut lettering. Lathing is a rotational process, and normally used to produce objects such as a pully or shaft. |
| You need a router or engraver. A router will do larger heavier items like Pic.2 below, and can do some engraving with a small collet and the correct bits. An engraver will also engrave as in Pic.1 below. I don't know why anyone would want a machine built solely for engraving instead of a router that can do both, although I think there are 'engravers' used in the jewellery industry. Maybe they are just small routers more suited to fine intricate work..... |
| Z position confusion | baldysm | MadCAM | 8 | 02-16-2007 09:46 AM |
| sofware confusion | craftech | General CAM Discussion | 9 | 10-24-2006 01:48 AM |
| Manual.doc vs. .ini confusion | medved | TurboCNC | 2 | 04-04-2006 10:18 AM |
| Multiplier confusion | Mike F | Servo Motors and Drives | 2 | 01-03-2005 01:36 PM |
| VFD confusion, helllp! | Swede | General Electronics Discussion | 10 | 06-14-2004 06:05 PM |
