Well after about a year or so being occupied with other stuff I've eventually started my own router. I don't have a machine shop so I'm trying to use prefab parts for everything, BigBlue saw etc may get some business making conversion plates. I'm beginning with 3"x3"x48" beams but the idea is everything works out I'll buy longer rails and belts to have a 4'x8'x6" cutting area. I may need to go to 3"x6" beams but I hope not. I'm starting with 8020 linear bearings and they seem good enough for a home router. I plan to splurge on the motors and controllers as I can re-use these on other projects. http://www.flickr.com/photos/moir/se...7600119819806/ I'll post progress as I go. Last edited by ajmoir; 04-25-2007 at 09:55 PM. Reason: Tidy Up |
| emc, yes that seems to be the best free program. unfortunaly i dont understand linux, and have read al about at, but can not figure it out ![]() now i have a trial version of mach3 (works till 1000 gcode lines) when i have my machine functional i will buy the license of mach3. good luck to your machine. |
| I’ll have to keep an eye on your build, I just recently finished a jgro style router and it does a good job for a pile of hardware store parts. I have been toying with the idea of building an 80/20 machine for awhile and have work up some basic plans. I am going to make a small PC board router around 12” x 14” I would like to try the 8020 slides but have my doubts, I use 8020 at work and know the slides aren’t too bad if you shim them up just right. I look forward to following your progress. Good luck! And good building! RobWms
__________________ Deeds not words... VoltsAndBolts Alternative Power Forums http://www.voltsandboltsonline.com/ |
| Oh, and another parallel, I am exploring Ubuntu & EMC2, The price is right! But am currently using AutoCAD, Ace converter and TurboCNC.
| Build is progressing, or should I say funds are diminishing. I think I have all the framing required except for 2xlinear slides from 8020. Watching ebay daily :-) Motors are purchased 3x34 and 3x23, I'll have 2x23 left over, Keling Gecko 201s purchased, Gecko where else Power supply purchased 50V/12V/5V, Antec Z-axis plates sent to BigBlueSaw for machining Various bits from McMaster Only thing left to build is the belt drives, it would seem nobody does bolt on belt drives for 8020, plenty of very nice drives for custom extrusions. There has to be a big market here for stuff that bolts to 8020. Anyhow I'm in the process of designing my own, Nema34 to an independent shaft with a directional roller above, should work. Emachine shop will probably get the business as it involves bending 1/4" plate 6060. I expect it to be pricey :-( One thing that is apparent is this hardware stuff is not as bendable as software :-( I have a small stack of parts that I bought and are not going to be part of the finished machine. Is this usual in machine builds or is it my lack of knowledge/skill that is causing it? |
| Well it continues :-) I just scored the slides from 8020 I wanted, should have them for this weekend. I picked up my breakout board, so my electrics are complete. Another lesson learned was that whenever you buy the 8020 extrusion always, always have the end holes tapped, I'm not looking forward to doing that this weekend. It would have been so much easier if I'd had the shop do it to begin with. The spindle stuff, z-axis, heat sinks etc is being sent to big blue saw. I recommend them as they have done good work for me. I have the designs for the belt drive finished and should have them sent by this weekend to emachine shop. Parts will be from SDP/SI. Parts still to have machined 3x belt drives 3x belt returns 1x z-axis mount plate 1x z-axis bearing plate 1x spindle mount 4x Gecko heatsinks/mounting plates I'll be posting my dxf files as I verify they are correct. End of this weekend I should have the frame all together, the electrics tested. I should also have all my remaining parts ordered. Looking forward to turning this thing on. |
#12
| Hi, took a look at your site and I have a question. You seem to pay no heed to aerodynamics, surely some sort of streamlined body/chassis would be a lot faster? The set up you have seems to be like pushing a house brick around? |
| Tags |
| 80/20 |
| Getting Started with CNC Router | aturner | WoodWorking | 10 | 11-23-2006 11:26 AM |
| router bits to get started | IYWD | WoodWorking | 5 | 10-29-2006 09:50 AM |
| Router build has started | Bruggles | DIY-CNC Router Table Machines | 7 | 07-01-2006 11:32 AM |
| Finally Started My Router Project | Ozinus | CNC Wood Router Project Log | 19 | 07-18-2005 05:46 PM |
| Started my 4X8 router | ninewgt | DIY-CNC Router Table Machines | 6 | 06-19-2003 08:45 PM |
