Old 04-22-2007, 10:40 AM
Appalachiatools is on a distinguished road
Question 4 Acme rods for a Z...Will it work? Help please!
I'm going to put this into cnc terms but this is not for a cnc router. It is for a home made saw mill. This mill has only an x and z axis. My question is for the z. What I have is four acme rods placed aprox 40" square holding the z "carriage" this carriage carries the weight of a 25hp Wisconsin engine and the bandsaw itself. Estimated weight of 600 lbs. Each side of the acme rods are connected by 1" ss rod with mitered gears with a chain drive between the two rods. There are four brass acme nuts on the top of the carriage, and four on the bottom (approx. 24" apart) The fellow that built this spared no expense and knew what he was doing. It is a great idea BUT, will it work? I am concerned of the play (which is minimal) between mitered gears and chain drive with the timing of all four acme rods. It would seem to me that binding might be a problem. What do you think? Thanks in advance!
--Rick
Old 04-23-2007, 06:30 PM
Netjams is on a distinguished road
Let me start by saying that sure sounds like a cool machine! (I want one)
From what your describing it sounds like the weight of what is on the Z is supported by 4 screws with brass nuts and drivin by chains. I don't think you have to worry about play because it will always have a load one way (the weight of the saw). Binding may be a problem if your motor isn't sufficiant to do the job. I think I would consider building a preload system (counter balance) but I would hook it to the motor some how so it always keeps the load on the chains and screws, then you may be able to pull it off. Then again it could fail if the saw cutting reduces the load.
Old 04-23-2007, 06:34 PM
After a closer inspection of what you posted I see your just concerened if it will work running it by hand. A picture would be worth a thousand words.
Old 04-23-2007, 08:36 PM
The weight is supported by the four acme screws by the eight brass nuts (four on top, and four on the bottom). The screws are turned by mitered gears, 2 each on 1" s.s. rods. The two rods are connected by a chain drive with one rod connected also by chain drive to a 1/2 hp 1800 rpm DC motor with a very large gear ratio (not sure of the ratio). Should have plenty of torque. This is a machine I am looking to purchase that is incomplete. I'm not sure if I would complete it as was intended. I'm not too concerned of the weight on the acme rods, but am concerned of the timing between four rods. It would seem to me that any play at all would cause binding. This may be unwaurranted. I've attached the best pictures I have to show this. It has a separate DC motor for the guide adjustment. I would want to computerize the Z and X axis if I do make this purchase which I am leaning to. Too much of the really good figured stuff always gets set to the side. I want my share! So it would be a CNC saw mill.
Thanks for the reply. I was really hoping for a lot of input on this before making the purchase.
--Rick
ID:	36050   Click image for larger version
Old 04-24-2007, 10:59 PM
Talking OK...It's mine now...Another project!
I'll pick this machine up in a few weeks and will be posting more pictures. It's got a really good engine, new clutch set up (really smooth) and the saw itself is built like a tank. completely rebuilt '46 Dodge powerwagon hubs turning 26" Cook band wheels. Cook blade guide system, sweet blade tracking set up...Nice! Might have to make some design changes to the Z but I really liked what this fellow did. Beautiful work, just not complete. Still would like more input on the original question of the four acme rods??? Can't wait to get it to the shop, build the X carriage, log dogs, loader, add the motors, drives, hydraulics, etc...etc...
Should have an easy 30 grand plus band mill for 5 + or -...usually +++ ...More to come! Gunna be a sweet project!
--Rick
Old 04-25-2007, 07:36 AM
Treischl is on a distinguished road
Without a lot of waffling around, I think it will work. I have seen chain drives that have a LOT more slop in them used to do the same sort of thing. When those four screws turn, it is going to go up and down.
Old 04-25-2007, 07:46 AM
samco is on a distinguished road
Old 04-28-2007, 11:57 PM
FastEddie is on a distinguished road
I work in an architectural millwork shop, and both our 24" planer and 36" wide belt sander use a 4 post screw arrangement with a chain. Both machines work flawlessly, and to an accuracy of a couple thousandths. I know the sander is driven with sprockets on the posts and an idler like the picture above. As long as the gears don't develop enough slop to jump teeth you shouldn't have a problem with alignment. Also, both machines have rubber boots covering the threads, keeps the dust out, mcmaster carr sells them, others too I'm sure...
Old 04-29-2007, 07:12 AM
Thanks for the replies. I'm sure that it will work. I'm going to add some rails and roller bearings from the carriage to the frame as right now the four acme rods are all that keep it from moving side to side or forward to back. I have the bellows from Mcmasters already mounted, just not stretched, but am concerned as to how they will hold up when the big chips start flying. Might get some heavier duty bellows. They are expensive! I'll know more when I pick this machine up and get it to my shop. Thanks!
--Rick
Art work Art Ransom Employment Opportunity 8 10-16-2006 09:01 AM
Looking for work JPMach Employment Opportunity 1 09-01-2006 12:47 PM
art work tmt_92021 Mastercam 6 08-19-2006 07:21 AM
Need Work j-radkemachine Employment Opportunity 0 07-10-2006 04:01 PM
PWM how does it work? CNCadmin Mach Plasma / Laser 9 08-16-2005 11:25 AM
