Old 04-13-2007, 12:11 PM
dwacker is on a distinguished road
All in one controller
I'd like to build a all in one controller. Since my laptop has no parallel port, I need to get another pc. I was thinking I could put the mother board and all the pc related parts in the same box as the cnc related parts.
Is there going to be a heat issue doing things this way?
I'm using xylotex driver and power supply. I was going to just use a micro atx mother board and small hard drive for the pc portion.
Don
Old 04-13-2007, 01:08 PM
wcarrothers1 is on a distinguished road
Guess that depends on the CPU you are running. I'd run them separate though. I have the camitronics power supply and I have so much stuffed in there (3 gecksos extra heat syncs switchs to switch the supply between my 2 machines, grex and lots a wiring.) it would be very tight to have all that in a large tower case.
Really all depends on your cooling fan in the case I guess. mine is just a regular mini tower case for the computer and I have a 120v 3" fan to suck the heat out and it still gets hot.
My power supply does not seem to make much heat at all though.
b/.
Weldtutor's Avatar
Weldtutor is on a distinguished road
Arrow All In One Controller
Originally Posted by dwacker View Post
I'd like to build a all in one controller.I was thinking I could put the mother board and all the pc related parts in the same box as the cnc related parts.
Hi Don
Check the photos in post #5 of THIS LINK which is what you want to do. The mini MB is visible in the 3rd photo.
I have a similar unit built by Mlaws1172 that does a fine job on My Plasma table.
Several fans are incorporated that prevent overheating.
Old 04-13-2007, 01:19 PM
Originally Posted by Weldtutor View Post
Hi Don
That is a sweet cabinet. I'm not sure I,m up to anything so nice but exaxtly the type of thing I had in mind. I do have a small metal box already that would house the boards but I doubt I could get the power upplies stuffed in there.
Without power supplies being in the box would heat be a issue with just a fan or three?
Don
Old 04-13-2007, 01:24 PM
Oldmanandhistoy is on a distinguished road
Hi Don
Just looked at post #5 and I think the fans have been taken too far with that big one on the underside of the case.
John
Old 04-13-2007, 04:16 PM
Weldtutor's Avatar
John,
I had to re-check the first 2 photos & now I see what you mean!
That gave me the best laugh of the week, thanks. Most systems normally do use much smaller fans.
Don, without the PSU in your enclosure you'd likely be OK with the fan or 3.
Mine has a large fan directed at the toroid transformer that is active when the controller is 'ON,' the normal fan on the CPU, & a third that causes air flow through the enclosure.
Old 04-13-2007, 04:53 PM
Gold Member
mlaws1172 is on a distinguished road
That is just a small fan we usually use much larger .
I do have a couple of cabinets that I would give away to anyone that wants them. You pay frieght. They are the big ones like I used on Bruces.
mike
Old 04-13-2007, 07:19 PM
mike
I would jump at one of those enclosures if you were on my side of the pond; they are an excellent looking job. I must admit the wiring of the machine is not my favourite part of machine building. I would like to have all electronic components in the same enclosure but am unsure of how close they could be without causing problems. I didn’t really consider heat as a problem as long as you have sufficient air flow. With your experience what would your tips be and things to be avoided while using a single enclosure?
So you flap a chair about to increase air flow, not a bad idea. Do you think that is how they did it before the invention of electric fans?
John
Old 04-13-2007, 08:31 PM
Weldtutor's Avatar
John
That is likely how they did it.
Don
Mike's integrated computer/controller has a nice big aluminum heat sink that the Geckos mount on to keep them cool.
That way you will not need those 20" fans that John noticed in the pictures, nor will you have to resort to 'flapping' of chairs.
Old 04-13-2007, 10:14 PM
11bravo's Avatar
11bravo is on a distinguished road
Please forgive me if this is just too simple an idea, but...
Why couldn't you just put your computer and control box inside a small refrigerator?
Like one of the dorm sized ones? (if they'd fit)
They are cheap to run.
Keep things cool.
Computers don't need fresh air, just cool air.
Could easily make access panels to run cabling out of.
Keyboard, monitor, and mouse outside of it.
Be pretty dust proof.
Am I missing something?
  #11   Ban this user!
Old 04-13-2007, 10:17 PM
Keep things cool.
Might be a serious problem with condensation?
John
  #12   Ban this user!
Old 04-14-2007, 10:49 AM
Thank for the replies. This is what I came up with from a junk pc. You can see the xylotex psu. The motherboard would go on the same panel to the left. The driver board on the floor panel or the drive bay. The HDD would go anny place the drivers didnt. Thats it no other pc parts I was just going to use a usb cd drive to load the HDD and then remove it.
Stop me if this looks like its going to have problems?
Is there a way to load a operating system onto the HDD without a cd drive?
Don
UHU Controller PCB or kit southernexplore Open Source Controller Boards 4 05-24-2008 02:20 AM
Need a new CNC controller Chris64 General Metalwork Discussion 0 12-10-2006 02:58 PM
New, H1 CNC Controller icm Product Announcements & Manufacturer News 4 09-03-2006 04:56 AM
Cnc controller. Smackre General Electronics Discussion 0 05-02-2006 08:56 PM
Controller Box drakesis General Electronics Discussion 2 06-19-2005 04:42 PM
