Old 04-12-2007, 10:46 AM
barnon is on a distinguished road
Pictures of first part off home built table
I just mounted a Trim Router I bought from Home Depot on my homebuilt CNC table. Take a look at the attached JPGs of a 4.5 inch diameter spur gear I cut out of MDF. I have few questions.
Where can I but a decent lightweight router spindle?
Do you need an adjustable speed spindle for cutting wood and plastics?
Thx for any help
ID:	35290   Click image for larger version
ID:	35291   Click image for larger version
Old 04-13-2007, 07:18 AM
Oldmanandhistoy is on a distinguished road
Hi nice job on the gear. Looking closely it looks like you did the outer cut in two passes? Can I see a bit of a lip going on there; are you loosing steps or could it be a bit of backlash?
Just out of interest how did you hold the material down to the table?
As for cutting wood; imo a variable speed router is a must or you will get burning issues and reduces tool life.
Where to get a spindle from; I will leave that for members on your side of the pond.
John
Old 04-23-2007, 10:02 AM
John.
Yes, I took several passed on the outer cut. My ball bushings on my X and Y are tight but my Z has some slop.
I held down the material with 3M double sided PSA tape. Works great.
Home built barfeeder Fudd General Metal Working Machines 2 01-28-2008 08:50 AM
Had You built CNC Plazma at home. sanjiv CNC Plasma and Waterjet Machines 1 01-10-2007 10:44 AM
Home built cnc lathe roni21702 Stepper Motors and Drives 2 02-11-2006 03:53 PM
A few pictures on my home brew RF-31 Arc Benchtop Machines 21 12-25-2005 03:14 PM
Home built controller Stephen General Electronics Discussion 1 09-22-2004 11:02 PM
