Old 04-08-2007, 09:16 PM
jfc11 is on a distinguished road
Encoders for Nema 23 Stepper motors
I am thinking of adding encoders to my xylotex set up using rogers interface board....what encoder do I need and were to get it...and has anyone done this yet?
Thanks,
Jim
Old 04-09-2007, 12:48 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
US Digital has inexpensive encoders that will likely fit your motors. Take a look through their web site.
Best,
BW
Old 04-10-2007, 01:08 AM
Torchhead is on a distinguished road
Are you losing steps now?
Are you afraid of losing steps?
Are you scraping work because of lost steps?
If you are losing steps it's better to address the cause even if you do decide to go with the position "monitor" system you listed.
All the encoders will do is shut the machine down if the position error is greater than a preset value.
With steppers they lose postion because they have been asked to do something they can't (outside the torque envelope of the motor) so there is nothing you can go in a closed loop system but slow the motor down to bring it back inside it's torque curve. Simply adding in more steps (which is not what the Rogers Board does) just results in adding insult to injury.
USDIgital E4 series with sticky adhesive works on most motors that have a rear shaft. You will need to get the centering tool they sell to install them and
make sure you get the tiny connector with the wires attached for the encoder or you will find it impossible to hook them up (:-(
Tom Caudle
www.CandCNC.com
Old 04-11-2007, 07:32 AM
jcc3inc is on a distinguished road
Encoders
See my post and pix in "Encoders with steppers" below.
Jack C.
Old 06-21-2007, 06:16 AM
shashank ayyar is on a distinguished road
Jack C.
what post and pics?? i don see it! know where i can read up on these encoders?
i dont know sqat!!! will be asking dumb questions
Old 06-21-2007, 11:14 PM
Glidergider is on a distinguished road
I think this is his post.
http://www.cnczone.com/forums/showthread.php?t=35451
Anyone using closed loops (encoders) on their stepper motors? RMS Stepper Motors and Drives 2 08-04-2006 04:23 PM
Stepper motors and encoders homebrewCNC Stepper Motors and Drives 7 03-30-2006 10:57 AM
Nema 34 Motors 434oz/in / which gecko ckrantz Gecko Drives 1 10-01-2005 03:21 PM
What encoders to use for these motors? Cold Fusion Servo Motors and Drives 9 06-02-2005 11:14 PM
Stepper motors, encoders... runnoahrun General Electronics Discussion 6 02-28-2004 09:59 PM
