First I was going to go with 1/2 acme. After a couple weeks I decided to go with ballscrews. I bought a single nut SKF 10mm system. What kind of accuracy am I to expect with this?
__________________ Proud owner of a Series II Bridgeport. |
| Typically, if its precision ground the error is around .0005/ft or less . If it is precision rolled, around .004/ft. The thing to watch with a single nut is backlash, The best is a preloaded nut but these put the price up quite a bit. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| http://www.linearmotion.skf.com/Cata...,13955&Lang=EN It's a non preload rolled. Yes yes, I know this is the lower end of ballscrews, but is it going to have decent precision?
I actually just got done making a very small first run try at a 3 axis machine. Bearings and screws seemed to work wonderfully. I now have a pair of bearings and screws which may work good for you. They are 37 inch long 1" dia , 4 turns per inch,route Maybe you would like to take a look . I have posted all the information that I thought I needed to use them. But it was just going to be to big of a project. Item number: 3804800919 http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3804800919 |
Gerry |
| Ballscrew Basics | Swede | Linear and Rotary Motion | 94 | 09-06-2011 07:23 PM |
| Revolutionary Linear Drive System | allanconway2 | Polls | 21 | 05-03-2009 09:27 PM |
| Which Ball Screws to use? | Willyb | Linear and Rotary Motion | 4 | 01-19-2005 09:49 PM |
| Ball Screws & Nut Advice | coolman | General Metal Working Machines | 1 | 12-24-2004 09:29 AM |
| Z-Axis and Ball Screws | samualt | DIY-CNC Router Table Machines | 15 | 01-10-2004 03:10 PM |
